Fire at Work - Mustang Evolution
Old 09-15-2006, 01:10 AM   #1
Thomas91169's Avatar
Fire at Work
Ok, not our plant but the recycling center next to us went up in flames. apparently they use wire to tie together giant bundles of compacted paper/trash. well i guess they were dragging one across the cement, and what happens when metal is dragged across cement? yeah, it either sparked under the bail or got so hot from friction it became a hot soldering iron and caught one bail on fire. the forklift guy, not knowing there were flames under the bail, threw it in with another pile.
at which point my mom(our receptionist) notices smoke and goes outside to make sure it wasnt our plant(we have 3 large buildings) and notices its the recycling center. i guess she walked over and said they looked like they were just doing a controlled fire of just a pile of bundles. somehow one bundle fell over and landed right next to another pile, which instantly went up. that pile went to the next and so forth and so on.
the recycling center is closest to our largest buildings (marked building 3 in Picture) that holds our largest panel line(we are one of the largest manufacturers of urethane insulated metal panel systems). this is THE line that can produce something like 50,000 square feet of 3.5' wide panels per day at full capacity, that is, if we could feed it enough coil/raw materials fast enough. this building houses numerous chemicals for the foaming process that takes place, if it were to have a fire, its likely all three buildings would melt to their pads from the heat of the resulting fire. our men scrambled to move flammable tanks and equipment from that side of the building, we had all forklifts moving **** like mad, all our junk coil packaging had to be thrown inside in matter of minutes, all hands on deck fire drill.
the fire jumped piles numerous times. the fire department was very strategic in how they fought this beast, but was very limited due to the nature of materials they were fighting. once one pile erupted, it would burn with immense heat. the bundles are compressed paper/cardboard, each bundle had a ****load of fuel and burning time, multiply that by about 10 bundles wide by 10 bundles long and 6 bundles tall to create a pile. as soon as a spot of a pile was smothered with water, you could see how wet it got, but a second or two later, the resulting heat would have it dried out and smoking and in a few more seconds that spot would light back up.
there was a storage shed sort of structure that housed alot of the bundles as well. once the fire reached it it was a lost cause. the heat coming off this thing made it into sort of an convection oven, since the high side of the eaves were pointing toward us, you could just feel the radiation. the heat melted the steel skins of the building within seconds. the rest of the steel framing lasted a good couple minutes, but one by one each main pylon just melted to its foundation in a sound i cannot describe, scary screeching moan sort of sound.
the fire then jumped once more and headed towards a long pile that went all the way and stopped a good 30 feet from our property line. thankfully, the wind was going in the opposite direction of our building, so the fire had a tough time going against the wind, and about a week ago they cleaned out a good 30 foot access route between their property line and the piles.
then the fire department got fed up with wasting time. 2 HUGE ****ING bulldozers came in. they gangraped each pile so to spread the heat, and it wasnt long before the fire was controlled enough to where you were like "dammit, nothings gonna explode"
the fire started at around 2:30 and was over at 4. i guess we made the evening news, and our CEO's interview was on it as well. im in the background (w00t) on them i guess.
two things that could have made the day 100x worse.
1) if the winds were northerly, the fire would have rushed straight to our building within seconds instead of working its way around.
2) if they didnt have a break between our property line and their piles
enjoy my crummy pics!
ID:	14567   Click image for larger version
ID:	14569   Click image for larger version
ID:	14571   Click image for larger version
ID:	14573   Click image for larger version
ID:	14575   Click image for larger version
ID:	14577   Click image for larger version
ID:	14579   Click image for larger version
ID:	14581   Click image for larger version
ID:	14583   Click image for larger version
ID:	14585   Click image for larger version
ID:	14587   Click image for larger version
ID:	14589   Click image for larger version
ID:	14591   Click image for larger version
ID:	14593   Click image for larger version
ID:	14595   Click image for larger version
Name:	API Work copy.jpg
-Thomas-
Old 09-15-2006, 07:15 AM   #2
Re: Fire at Work
I bet the person who did that feels rather stupid
Old 09-15-2006, 08:50 AM   #3
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
Re: Fire at Work
daaaaang
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 09-15-2006, 10:17 AM   #4
bluemustang's Avatar
Re: Fire at Work
Glad everyone is fine and ish
but thats pretty badass to witness on the random. Yes i know thats the pyro within me talking
Old 09-15-2006, 11:06 AM   #5
wiarumas's Avatar
Re: Fire at Work
holy ****.. those pics are awesome.
Old 09-15-2006, 07:50 PM   #6
Re: Fire at Work
btw i just added a nice little topographical diagram of the path.
-Thomas-
Old 09-15-2006, 08:24 PM   #7
Zim
You want to **** me?
Zim's Avatar
Re: Fire at Work
wned:
I like toys
Old 09-15-2006, 09:15 PM   #8
Fishers Stang's Avatar
Re: Fire at Work
sweet!! o i mean sorry bout ur job.. looks like some good fire
Charles
Old 09-15-2006, 10:45 PM   #9
Seph's Avatar
Re: Fire at Work
holy crap!
-Patrick
http://home.socal.rr.com/sephiros/images/NewBan.jpg
Seph is offline   Reply With Quote
Old 09-16-2006, 03:07 PM   #10
Re: Fire at Work
lol wasnt my job. our place is fine, our buildings would have just laughed at the fire.
-Thomas-
Back Fire HELP kack85 Pre-2005 V6 Mustang 0 09-11-2009 05:41 PM
Night Of Fire at7311 The Bar 9 09-25-2006 10:12 AM
fire in the disco tedness The Bar 8 11-30-2005 10:59 PM
O'Reilly under fire damustangfan14 The Bar 10 10-15-2004 12:17 AM
04:32 AM
