need help changing door lock cylinder on my 98 - Mustang Evolution
Old 09-25-2006, 07:40 AM   #1
Hey all,
I bought a used door from a guy to replace a dented one i had. I need to swap out the lock cylinders though, does anyone know how to do this on a 98?
DrinkCraftBeer.com
dvon1981 is offline   Reply With Quote
Old 09-25-2006, 11:55 AM   #2
bluemustang's Avatar
Re: need help changing door lock cylinder on my 98
take apart the door, if you remove the door panel you can see how everything is put together.
I havent taken a mustang door apart BUT most doors have the handle and cylinder all as one and usually thats held on by a clip and or 2 10 mm bolts
Old 09-25-2006, 01:25 PM   #3
hmmm ok i'll try and look, i popped the door panel off on sunday, but then i started to rain so i had to head inside. It's damn tough to access that area, there's not a hole in the door right by the lock/ handle so you have to reach up through the door.
Anyone else ever done this before?
DrinkCraftBeer.com
Old 09-25-2006, 01:38 PM   #4
if u can take a pic i can tell u exactly how to take it off. there really not that hard just takes patience and extentions are your friend believe me
Old 09-25-2006, 01:59 PM   #5
sadly my mustang is up in NH and I'm in Boston, I'm headed back up this weekend. I'm sure I can figure it out, I was just hoping there might be a "how to" somewhere to use as a guide.
DrinkCraftBeer.com
Old 09-25-2006, 02:02 PM   #6
doors are self explainatory (sp?) really. just make sure window is up and panel is off have a flash light and look at it. Like i said most usually come off as an assembly with handle. usually all u have to do is push away the plastic clips that hold the metal hangers and then either a clip is around the clyinder itself (which is usually the *****) and then 2 10 mm bolts and she should come right out
Old 09-25-2006, 02:26 PM   #7
Cool, hopefully it'll go well this weekend.
DrinkCraftBeer.com
Old 09-25-2006, 03:20 PM   #8
yeah id say for someone whos never done that 20 mins top
if u have issues have ur digi ready and snap pics and i can def help u out quicker then.
Door Lock Trouble pmushock 1996-2004 Mustang GT 4 04-24-2009 08:16 PM
Ignition lock cylinder Babydoll General Mustang Discussion 5 01-05-2009 04:51 AM
Sprayed in bedliner and billet fuel door with lock... Rick0636 The Bar 21 08-06-2005 11:42 AM
door lock problems WhiteStang99 Pre-2005 V6 Mustang 9 04-06-2004 04:36 PM
10:58 AM
