Question about Dyno's and corrections - Mustang Evolution
Old 12-09-2006, 09:14 PM   #1
Kiljosh's Avatar
I was just reading a thread and saw those darn 3 letter acronyms thatr I dont know what they mean again.
Why do you need to correct a dyno graph to SAE or STD numbers and what do they mean?
Old 12-09-2006, 11:05 PM   #2
Re: Question about Dyno's and corrections
Correction factors are when you take the actual, uncorrected, numbers and run them through a formula. basically, SAE takes your uncorrected numbers and determines what they would be at 1 atmosphere of pressure and 60* F...and some humidity. This way, you can have a standard comparison for values around the country. For example, my numbers...which is prolly the thread you are talking about. I put down almost 500 hp. Well, most of that was because it was only 44* in the shop and 9% humidity. The correction says that if it were 60* and the pressure was 1 atmosphere, then I would have made 454. This way, someone in colorado can compare his numbers to someone in louisiana and see how close they are since colorado is not good air for power due to it being so thin.
I don't know the exact details to the formulas, but I know each applies different values to arrive at a common number. It is mainly for a basis of comparison. Uncorrected is what you actually put down on that day. SAE, STD, and the other factors are what you make in the conditions of the correction.
Make sense?
midwest mustangs dyno's turbofox General Mustang Discussion 3 06-09-2010 09:29 PM
just a question USMC Roush The Bar 5 02-20-2009 07:37 PM
To GT or not to GT that is the question timpryor The Bar 30 03-30-2006 08:29 AM
new here and have a question? cheese2die4 Mustang Audio & Video 13 03-02-2005 07:13 PM
Question Austin Mustang Wheels & Tires 6 05-15-2004 10:37 PM
03:52 AM
