Interesting Fuel Article - Mustang Evolution
Old 06-02-2007, 08:39 AM   #1
meteorachick's Avatar
Its definately worth the read.
Get 50 mpg -- in your own car - MSN Money
Modified 2004 V6
Old 06-04-2007, 04:48 PM   #2
bullitt482's Avatar
Re: Interesting Fuel Article
Pretty much that says don't accelerate fast and obey speed limits......
Not trying to hate on your idea, because it does help, but you can't tell me that doing 70 in some cases will get better than doing 90.
Example. Made it from here to memphis in less than 2 hrs. We did 100 or so a lot of the way. The car got 23.7 mpg. On the way back went slower becase of less traffic, got 20. That was in the notch.
Hell, in the bullitt we made it from columbus to atlanta in less than 4 hours and got almost 27 mpg. Different cars have different efficiency ranges.
01 Bullitt
Old 06-04-2007, 05:10 PM   #3
I can't really see how driving 50-55 in a 60 zone where most people are going 65 is very safe. Just causes more mess with people trying to pass the slow people, even if they are in the right lane. Better to flow with the traffic IMO.
Fred_Meyer is offline   Reply With Quote
Old 06-05-2007, 04:51 AM   #4
I didn't read the article, but i think its supposed to have something to do with the drag increasing as you increase speed in a non-linear fashion.
ThaWill is offline   Reply With Quote
Old 06-05-2007, 07:18 AM   #5
Just remove air and lower gravity and we can get much better MPG.
Old 06-05-2007, 09:25 AM   #6
Thomas91169's Avatar
has alot to do with the motor too. if you drive too slow in 5th and the motor is bogged down, you must use more throttle input to keep up speed. if you drive faster in that same gear and the engine is closer to its efficiency range you use less throttle input.
i know when i use 5th around town its like you can watch the needle go down because im bogging the motor at 1300rpm, and theres no acceleration to be had unless you drop two, i usually like to keep the 4.6 around 22-2500rpm if at all possible, and save 5th for the freeway. the above scenario is the patrol officer stalking me scenario.
-Thomas-
Old 06-06-2007, 05:28 PM   #7
bullitt482's Avatar
So pretty much your saying this
01 Bullitt
Old 06-06-2007, 06:30 PM   #8
I learned how to save gas on the way up to Tupelo last weekend...get in the slip stream of an 18 wheeler and cruise. The box ranger was cruising in no wind...it was sweet. I could also keep up with traffic that way
Interesting Article on Saving Gas meteorachick The Bar 14 06-05-2008 09:07 AM
Interesting Article n8r The Bar 7 06-29-2007 08:30 PM
Interesting article I found bbunt302 The Bar 6 02-24-2007 09:22 PM
A very interesting article I found... bbunt302 General Mustang Discussion 20 05-26-2006 04:03 PM
Interesting article Rick0636 The Bar 2 05-29-2004 01:02 PM
05:58 PM
