Question of physics: - Mustang Evolution
Old 06-05-2007, 07:58 AM   #1
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Let's say that I have an airplane sitting on the runway. Fully loaded it weighs in at 377,842 kilograms. It has four engines capable of developing 28,710 kg of thrust each, or 114,840 kg total. The thrust/weight ratio, therefore, is .30396.
I'm trying to determine the rate of acceleration of my aircraft down the runway when full power is applied. Can any of you physics experts lend me a hand?
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 06-05-2007, 08:48 AM   #2
Y2E0L0L5OGWT's Avatar
Re: Question of physics:
Before the problem can be solved, there are some things that need to be addressed..kg's aren't a measure of weight. lbs or in this case because you are using the metric system, newton's are the measure of weight/force. you don't need to know the thrust to weight ractio really...all you need to know is that F = ma...where a is the aircraft's acceleration, m is the mass of your aircraft, namely 377,842 kg, F is the thrusting force of the aircraft which we don't really know because you gave us thrust is kg. Thrust is a force, and therefore we need it in newton's which technically means we would need to know the acceleration of the engine exhaust flow...Also, I am assume you are neglecting all frictional and aerodynamic forces during takeoff? and also ignoring the fact that your weight is changing during takeoff as fuel burns? (by the way, I am an Aerospace Engineer, so sorry if the answer is a little convoluted)
Old 06-05-2007, 08:52 AM   #3
MarkuzLS1's Avatar
Thrust: 253,200 lbs
Weight: 833,000 lbs
I had converted everything to metric...so here it is in standard.
Yeah, there's no need to worry about changing weight due to burning fuel and frictional losses due to air and rolling resistance.
I like turtles.
Old 06-05-2007, 08:55 AM   #4
Thrust: 253,200 lbs
Weight: 833,000 lbs
ok now the problem is easy...simply take the weight of the aircraft, 833000lbs and divide it by the acceleration due to gravity which is 32.174 ft/s^2 to get the mass of the aircraft, Then use F = ma to solve for the aircraft's acceleration down the runway in ft/s^2. F = Thrust, m = mass of aircraft...make sense?
Old 06-05-2007, 08:58 AM   #5
should get approximately 9.8 ft/s^2 ish
Old 06-05-2007, 09:05 AM   #6
MarkuzLS1's Avatar
Gotcha. It all makes sense, now.
I like turtles.
Old 06-05-2007, 09:17 AM   #7
Thomas91169's Avatar
if this was another airplane on a conveyor belt question i was gonna go ape****!
-Thomas-
Old 06-05-2007, 09:37 AM   #8
"What is the airspeed velocity of an unlaiden swallow?" :dunno:
Old 06-05-2007, 09:38 AM   #9
MarkuzLS1's Avatar
What do you mean? African or European?
I like turtles.
Old 06-05-2007, 09:39 AM   #10
MarkuzLS1's Avatar
No, it was an acceleration of a 747 question... :dunno:
I like turtles.
Old 06-05-2007, 01:59 PM   #11
all you need is a steam catapult
ThaWill is offline   Reply With Quote
question Kyle ME Site Help & Announcements 6 04-15-2008 11:40 AM
Question coolstang Pre-2005 V6 Mustang 2 07-01-2007 12:42 AM
Physics gods: Step in and help me out here Brent The Bar 29 04-25-2006 08:47 PM
Physics help... I'm stuck WhiteStang99 The Bar 21 02-16-2006 03:11 PM
question Dark02Pony The Bar 4 07-12-2005 03:52 PM
03:27 AM
