****!!! I dropped my external HD... - Mustang Evolution
Old 07-09-2007, 09:05 AM   #1
wiarumas's Avatar
I have an external HD and I accidently moved my laptop far enough to yank the thing off the dresser and it fell about 2-3 feet onto hard wood floor yesterday. There is no visible damage, and the thing works 100% fine. It kinda fell upright and onto a corner so i guess it was sturdy enough to withstand the fall? It was also on, but no data was being used.
My question is, do you think it is okay? I want to be cautious even though it works fine... I don't want it to one day stop working and all my hard work downloading and backing up data to disappear...
I used it for about 2-4 hours and no problems yet... no noises.. no nothing. Think I'm in the clear? I don't wanna dish out another 130 for a new one :-\
Old 07-09-2007, 09:08 AM   #2
Herbstang's Avatar
Re: ****!!! I dropped my external HD...
If it's running you should be fine ,Count your blessing
Old 07-09-2007, 09:10 AM   #3
Sounds like its doing ok...
Old 07-09-2007, 09:22 AM   #4
Y2E0L0L5OGWT's Avatar
I would back up your important stuff on another form of media if you can (i.e. dvd's or the like)...generally speaking, external HD's are built much studier than typical hard drive's...well, at least the outer casing is...a typical laptop HD is only designed to withstand about a 1" or 2" fall, which is kinda scary if you think about how many times you've just sat your laptop down kinda rough without really thinking about it...your external HD should be fine if it's still running without any grinding noises or anything...
Old 07-09-2007, 09:31 AM   #5
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Dropping it while it's running is pretty dangerous. They don't respond well to contact between the platters and the read/write head. Backing your stuff up is a good idea (it's a good idea to do routine backups, anyway), but if it hasn't catastrophically failed already, you're probably good.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 07-09-2007, 09:42 AM   #6
wiarumas's Avatar
I think its fine then. I transferred about 20GB to it, and took about 5GB from it with no noises or problems at all. However, I'm going to back up the important stuff... Battlefield 2, SimCity4, StarCraft + Brood War, etc.
17x10s on dropped 92 onequickR Mustang Wheels & Tires 8 01-15-2010 10:16 AM
Dropped a point in my GPA MonteCitan The Bar 13 12-22-2007 01:30 PM
I just dropped over 4 seconds in the quarter with ONE MOD KyleUSAF Pictures and Videos 38 07-09-2007 09:48 PM
Look what the Ups man just dropped off w00t timpryor Pictures and Videos 13 02-12-2007 08:07 AM
06:27 PM
