New Computer Build Up! - Mustang Evolution
Old 09-07-2007, 10:34 PM   #1
Seph's Avatar
Alright guys, it hasn't even been a full month and my computer has already started to act like it did when I was going to reformat it. New computer time, and this time instead of going through Alienware, I'm building it myself. Here are the specs on the computer, I'm hoping it'll be a huge improvement over the last with less headaches. So please, if you see any hardware that doesn't look like it'll do too well, or if you see there being a chance of hardware conflicting or not even being able to take it, tell me! This is my first build. Thanks guys It'll help Brent a lot too so I wouldn't have to continue calling and IM'ing his *** every time my Alienware farts out another crapper.
Newegg.com - Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail
Newegg.com - GIGABYTE GA-965P-DS3 LGA 775 Intel P965 Express ATX Intel Motherboard - Retail
Newegg.com - EVGA 640-P2-N821-AR GeForce 8800GTS 640MB 320-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card - Retail
Newegg.com - Antec SmartPower 2.0 SP-500 ATX12V 500W Power Supply 115/230 V TUV, UL, CUL, CE, CB, FCC - Retail
Newegg.com - Intel Core 2 Duo E6850 Conroe 3.0GHz 4M shared L2 Cache LGA 775 Processor - Retail
Newegg.com - mushkin 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
Newegg.com - Western Digital Caviar SE16 WD4000AAKS 400GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
So I'm missing a heatsink right now, that I know I need to look into getting.. anything else I might be missing?
-Patrick
http://home.socal.rr.com/sephiros/images/NewBan.jpg
Seph is offline   Reply With Quote
Old 09-07-2007, 10:39 PM   #2
Thomas91169's Avatar
Re: New Computer Build Up!
i like that case, talk about airflow. little expensive but itll last you many a setup.
otherwise its a pretty solid setup, especially the 8800. i might suggest going with a larger power supply though.
-Thomas-
Old 09-07-2007, 11:01 PM   #3
Seph's Avatar
Yeah a friend of mine built his computer with that case, he's got fans GALORE in that thing. He says his PC stays cooler than the rest of his room.
Got any suggestions on which power supply to get?
I was a little hesitant on the motherboard, but my buddy told me to go to some overclocking websites and find one that has good reviews and that stays at great temps when over clocked. This way it'll handle doing it's normal thing without a hitch.
-Patrick
Old 09-07-2007, 11:30 PM   #4
Seph's Avatar
Wow, how's this one look? I can get it combo'd with the case and get 80 bucks off it.
Newegg.com - Antec TruePower Quattro TPQ-1000 ATX12V / EPS12V 1000W Power Supply 100 - 240 V UL, CUL, FCC, TUV, CE, C-tick, CCC, CB - Retail
-Patrick
Old 09-08-2007, 12:20 AM   #5
Originally Posted by Seph View Post
when your power supply has racing stripes............
a 500w will likely be fine, however if you dont want to have to worry about upgrading for a long while, id get something like a 600w+.
-Thomas-
Old 09-08-2007, 12:48 AM   #6
Seph's Avatar
lol I guess I'll take that combo deal then :yup:
-Patrick
Old 09-08-2007, 11:37 AM   #7
bbunt302's Avatar
It's nice to see everyone building with Intel chips these days.
Scary stuff.
Old 09-08-2007, 05:27 PM   #8
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
that 8800 series gfx card will tax a 500w psu under load. at minimum, you should get a 620w. take a look at the corsair hx620.. here's a very good deal on it
also, the ga965 IS a very good board, but the processor you have listed won't work with it. the e6850 is one of the newer conroe chips, it runs a 1333mhz fsb. the ga965 only accepts an fsb up to 1066mhz...
so, either downgrade your processor to a core2quad for ~$268
..or upgrade the motherboard to a p35 series chipset. here's a gigabyte p35 for about the same price as the p965 you have listed
the mushkin you have listed is decent, but i'd take corsair xms2 @ 800mhz or crucial ballistix @ 1066 over it in a heartbeat. zipzoomfly has both, with better prices than newegg+ free shipping
don't forget, you still need sata hard drives and a sata dvd burner
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 09-08-2007, 05:29 PM   #9
dark's Avatar
also, for a very good heatsink, check out all things by Thermalright. they're currently THE name in air cooling
performancepcs.com
NCIXUS.com - Great Technology, Selection and Service.
www.heatsinkfactory.com
all have good selections
Old 09-08-2007, 07:51 PM   #10
Seph's Avatar
Aaah thank you Dark, I appreciate the advice and I'll look into all of the links. Quad core that much of a difference to get over the dual?
-Patrick
Old 09-09-2007, 07:12 PM   #11
dark's Avatar
for real world performance, no, there's not much advantage to a quad core RIGHT NOW. but in the next 6 months or so there will be a lot more. i just listed the quad because it's the best thing you could use with the mobo you had listed, and the deal on it is very nice. but for myself, i'd keep the e6850 and step the mobo up to the p35. the price works out about the same eitherway...
...or else get an nvidia 650i or 680i. i'm putting an e6550 onto an evga 680i... it's gonna be freakin fast
Old 09-09-2007, 11:46 PM   #12
Seph's Avatar
pics of my buddy's rig
ID:	17943   Click image for larger version
-Patrick
Old 09-09-2007, 11:49 PM   #13
Looks like a decent setup. That video card will do you good for a long time.
Old 09-10-2007, 12:07 AM   #14
Seph's Avatar
I changed up the setup thanks to a talk with Dark and a friend of mine at work. So now it's looking like this
Newegg.com - GIGABYTE GA-P35-DS3R LGA 775 Intel P35 ATX Intel Motherboard - Retail
Newegg.com - CORSAIR CMPSU-620HX ATX12V v2.2 and EPS12V 2.91 620W Power Supply 100 - 240 V UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick - Retail
Newegg.com - Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory - Retail
Newegg.com - Western Digital Caviar SE16 WD3200AAKS 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
Thermalright IFX-14 CPU Cooler
Serial ATA II Data Cable with latching mechanism 25cm (10") - Straight to Right Angle - UV Blue Products Model: SATA2-UVB-SR-10 [SATA2-UVB-SR-10] : Performance-PCs.com, ... sleeve it and they will come
Arctic Cooling MX-2 Thermal Compound - High Performance Thermal Compound - Enthusiast Products Model: ACTC-MX2 [ACTC-MX2] : Performance-PCs.com, ... sleeve it and they will come
Thermalright HR-03 PLUS Aluminum Heatpipe VGA Cooler Products Model: HR-03-PLUS [HR-03-PLUS] : Performance-PCs.com, ... sleeve it and they will come
A.C. Ryan Blackfire4 Kameleon (Special Edition) UV LEDFan - 120mm- Sleeved Products Model: ACR-BF50657 [ACR-BF50657] : Performance-PCs.com, ... sleeve it and they will come
And I figure like.. any sorta DVD burner will do.
-Patrick
Old 09-10-2007, 12:30 AM   #15
i just got one at best buy for 35$. its SATA controlled as well. vary nice!
btw im trying to find a fan like his, but they all come with ****ing LED's! im going to de-rice my case, get better 120mm fans (Markuz lemme know that site that had the good 120mm fans!) and possibly get a better case (however not no freaking 150-300$ one, just plain black).
-Thomas-
Old 09-10-2007, 12:33 AM   #16
Seph's Avatar
What brand? I was just going to buy a Samsung or something, my brother got an HP and that thing's been pretty solid.
-Patrick
Old 09-10-2007, 12:39 AM   #17
yup mine is Samsung, model # SH-S183. i had to get Sata connectivity because my MoBo only has 1 IDE array (enough for my two old IDE storage drives).
-Thomas-
Old 09-10-2007, 04:00 PM   #18
Seph's Avatar
That works.
I'm curious with the setup I posted recently if I am missing anything other than the DVD burner? Time is coming up where I'm going to buy everything in a large chunk.
-Patrick
Old 09-10-2007, 07:48 PM   #19
Zim
You want to **** me?
Zim's Avatar
whats that setup end up costing there seph? im also getting a new comp here in the next month or so
I like toys
Old 09-10-2007, 08:00 PM   #20
Seph's Avatar
Right now, it's looking like somewhere in the 1500-1700 range with how things sort of look. Just the motherboard, video card, and case alone is 600 bucks.
-Patrick
Old 09-10-2007, 10:32 PM   #21
your first build will always be the most expensive, especailly if you are going all out. however from now on, you will have a power supply, case, fans, that will all be used for years to come, and likely last 2-3 builds before the show their age.
-Thomas-
Old 09-11-2007, 01:22 AM   #22
Seph's Avatar
Ah that's true, good way of looking at things lol doesn't hurt the wallet too badly I guess.
-Patrick
Old 09-26-2007, 02:08 AM   #23
Seph's Avatar
w00t. Case, Power Supply are here. Heatsink+Fan, cable, and another 120mm fan just ordered.
-Patrick
computer nerds unite... need to build a tower jimmy_beaner The Bar 54 03-03-2007 06:53 PM
So I think I want to build a computer... fast64 The Bar 13 12-23-2005 07:48 AM
HELP need to build a cheap computer! SpectorV The Bar 4 08-14-2005 04:00 PM
Build a 3.8? FloMasta24 Pre-2005 V6 Mustang 7 03-07-2005 07:32 AM
Computer problem....for all you computer gurus.. Rick0636 The Bar 59 02-19-2005 10:42 PM
10:45 AM
