Grand prix coolant issue... input? - Mustang Evolution
Old 10-31-2007, 07:12 AM   #1
Today when I pulled into my parking spot at work as soon as I put the car into park (before shutting it off) the coolant began to smoke and come out of the hood, mainly on the drivers side. I turned the car off after backing it up a tad (i was over the curb and thought I might have hit something on accident). I looked under the car's front bumper and didnt notice anything~
I poped the hood and the spew seemed to have started on the bottom right side (there are some hoses down there) I hope its not a head gasket but by the looks its something else as there was a ton of coolant on the bottom right.
How do I need to go about driving the car if its low or has no coolant? I do NOT want to damage it~ todays temps are going to be 70~ I have heard you can drive a bit and watch the temp and stop and let it cool off as you reach 200 degrees or so~ and continue doing that. I am 7 miles from home (interstate) or 8 miles back roads.
input?
Old 10-31-2007, 07:23 AM   #2
Re: Grand prix coolant issue... input?
Uhm...run the heater and take your time..you should be fine going back to the house in it. As far as what it is...check all the hoses first, push on them, crimp them, see if there are any cracks in it.
Old 10-31-2007, 07:54 AM   #3
MonteCitan's Avatar
Was it bottom right (driver's side) as in 'looking towards the back of the car' or bottom right as in passenger side? (looking towards the front of the car )
If it was on the drivers side .. that's where mine failed, my radiator blew out...
and as per driving it home.. remember that the temp gauge won't quite respond right if there's no coolant in the block...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 10-31-2007, 09:17 AM   #4
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Yeah, I was gong to say, it measures coolant temps so if there is no coolant is will pretty much be measuring it's surrounding atmosphere.
For just 7 miles you should be fine, if you go back roads, do you have to stop and start a lot? I ask because a lot of acceleration will make it unhappy. If you go interstate, don't go to far above 2k if you can help it.
DarkShadow is offline   Reply With Quote
Old 10-31-2007, 09:25 AM   #5
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
If it's low on coolant, top it off with tap-water until you get it back to the house. You certainly aren't going to want to run it dry.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 10-31-2007, 09:29 AM   #6
DarkShadow's Avatar
It will probably leak right out though is the only thing.
Old 10-31-2007, 09:35 AM   #7
MarkuzLS1's Avatar
Depending on how bad the leak is... it might get him back to the house. Better than starting off dry, anyway.
I like turtles.
Old 10-31-2007, 10:06 AM   #8
I am pretty sure its a hose leak so I am going to pop a new one on and put coolant in it and it hopefully will be good.
Old 10-31-2007, 10:08 AM   #9
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
^werd
when my water pump died on the interstate, i stopped, filled the radiator with tap water and let it cool for a while. turn the heat on full blast and watch the gauge. i made it home, takin it very easy etc
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
D1 Grand Prix RoadStar Car Show Aug 22nd @ E-Town (Win Cash Prizes!!) Dubs Films Regional Mustang Discussion 2 07-24-2009 11:43 AM
Fellow V6 Stang and Grand Prix GT and a Jeep v6stanger Pre-2005 V6 Mustang 14 09-30-2006 10:30 AM
Anyone hear about the new Grand Am/Prix? Seph General Car Discussion 5 09-29-2006 10:42 PM
Grand Am GT lowflyn Pre-2005 V6 Mustang 11 01-31-2006 03:11 PM
Question about a grand Prix..please help! Sublime782 The Bar 15 12-01-2005 08:26 AM
12:33 AM
