05-25-2012, 10:09 AM
#1 | | Registered User
| Tried to break in car!
I slept over at my girls house last night. And my car alarm went off at 6 in the morning and when I run out to see what it is no one was there I turn off the alarm and check the car looks fine. When I open the door I realize someone tried to break in and damaged my window. Here are some pics I'm so fricken mad i can punch someone! Is it fixable or do I have to get a new one?
__________________  )02 Gt, Founder of WE2G
05-25-2012, 10:14 AM
#2 | | Registered User
Looks like you might need a replacement. Sorry.
1998 Mustang Gt, MSD coils, Ford Racing lowering springs, KYB shocks, caster camber plates, Flow Tech exhaust, K&N CAI, auto trans with shift kit, Jet Performance module, full length sub frame connectors, Redline Tuning hood struts. Oh yea, forgot to mention the Plasti Dip stripes.
05-25-2012, 10:15 AM
#3 | | Legacy Member
| Re: Tried to break in car!
I'm not sure how you would fix that... except with a new window.
__________________ SOLD! 2002 Sonic Blue GT, 5 Speed
05-25-2012, 10:20 AM
#4 | | Registered User
Alright thnks guys. Dammit there goes some money down the toilet
05-25-2012, 10:33 AM
#5 | | Legacy Member
You might be able to find one somewhat cheap.
05-25-2012, 10:36 AM
#6 | | Registered User
| Quote: |
Originally Posted by jimmy_beaner You might be able to find one somewhat cheap. | Is a job I can do in my garage? Or do I need a shop to replace it
05-25-2012, 10:38 AM
#7 | | Legacy Member
If memory serves correct from replacing my window track (and motor)... it shouldn't be anything too difficult (as I did more in my apartment parking lot). You'll need a drill to drill out rivets, some basic hand tools (ratchet and what not), and a rivet tool.
05-25-2012, 10:48 AM
#8 | | Registered User
| Quote: |
Originally Posted by jimmy_beaner If memory serves correct from replacing my window track (and motor)... it shouldn't be anything too difficult (as I did more in my apartment parking lot). You'll need a drill to drill out rivets, some basic hand tools (ratchet and what not), and a rivet tool. | Ok I have those tools so I'll probably give it a try. Maybe there's a how to somewhere on google. Thnks a bunch
05-25-2012, 10:57 AM
#9 | | Registered User
I work for an autoglass company, if you have full glass coverage your insurance should replace it, it usually depends when it's not the front windshield. If you have any relative experience you should be able to do it yourself, but it may take a lot longer than a shop could, should be under $100 for the glass itself, find out what else you'll need to replace it.
In short I'd give your insurance company a call first then your local autoglass shop to see how much/what you'll need if they don't help call a Ford dealer and ask for the parts department theyre nice people and should hook you up just have your VIN ready( ask for the driver side door window part number if it needs anything like moldings ect.)
__________________ 2006 JetWolf Mesa, AZ. Come race me, I dare you.
My man...? Yeah, you cant beat that.. don't even bother..! J/T & S/J |
05-25-2012, 10:59 AM
#10 | | Legacy Member
You take out the weather stripping and disassemble the door components. Start by removing the speaker cover (it pries off with a screw driver pretty easy), then unbolting it. Unbolt the mirror. The mirror and speaker are now free. Pull the lock pin if you have after market ones (stockers should be ok). Remove the door handle cup. You should be about at the point you can remove the inner door panel. If memory serves, you should now be able to see how the weather stripping on the door is fixed. Roll window half way down (this can be done earlier). Remove window from track (this can be difficult). Put new window in track. I believe I bolted the window back to the track with LocTite. Reassemble.
I may be missing some steps.
05-25-2012, 11:05 AM
#11 | | Registered User
Freaking turds out there. Can't make something of themselves so they make things harder on contributing members of society, all because they want free stuff. Sorry to see that.
05-25-2012, 11:23 AM
#12 | | Registered User
| Quote: |
Originally Posted by JetWolf I work for an autoglass company, if you have full glass coverage your insurance should replace it, it usually depends when it's not the front windshield. If you have any relative experience you should be able to do it yourself, but it may take a lot longer than a shop could, should be under $100 for the glass itself, find out what else you'll need to replace it.
In short I'd give your insurance company a call first then your local autoglass shop to see how much/what you'll need if they don't help call a Ford dealer and ask for the parts department theyre nice people and should hook you up just have your VIN ready( ask for the driver side door window part number if it needs anything like moldings ect.) | Hmm I doubt I have glass insurance but I'll give it a shot. If I don't then I'll either look on Craig's or call ford thnks. ---------- Post added at 10:23 AM ---------- Previous post was at 10:22 AM ---------- Quote: |
Originally Posted by jimmy_beaner You take out the weather stripping and disassemble the door components. Start by removing the speaker cover (it pries off with a screw driver pretty easy), then unbolting it. Unbolt the mirror. The mirror and speaker are now free. Pull the lock pin if you have after market ones (stockers should be ok). Remove the door handle cup. You should be about at the point you can remove the inner door panel. If memory serves, you should now be able to see how the weather stripping on the door is fixed. Roll window half way down (this can be done earlier). Remove window from track (this can be difficult). Put new window in track. I believe I bolted the window back to the track with LocTite. Reassemble.
I may be missing some steps. | Sweet thanks this is very helpful I'll definately save this for the future for now look for a glass
05-25-2012, 12:02 PM
#13 | | Registered User
Try junk yards as well... Www.cat-part.com will tell you what the closest one to you with the glass is
2001 Ranger Edge 4x4 xcab (sold to cousin) 4.10 Gear/RPM thread |
05-25-2012, 03:41 PM
#14 | | Legacy Member
For what it's worth, I could probably do it in an hour or less after re-familiarizing myself with the car. It's not that hard, it's just knowing how it's put together and what not.
05-25-2012, 04:03 PM
#15 | | Registered User
| Quote: |
Originally Posted by jimmy_beaner For what it's worth, I could probably do it in an hour or less after re-familiarizing myself with the car. It's not that hard, it's just knowing how it's put together and what not. | Ya I knw what you're saying. Were do u live lol so u can do it for me (: n do u knw if any 99-04 mustang window will fit I'm sure their all the same but why not ask
05-25-2012, 06:08 PM
#16 | | Registered User
| Quote: |
Originally Posted by Venomouz831
Ya I knw what you're saying. Were do u live lol so u can do it for me (: n do u knw if any 99-04 mustang window will fit I'm sure their all the same but why not ask | Yes they will all work..
05-25-2012, 08:28 PM
#17 | | Registered User
| Quote: |
Originally Posted by 2002VertGT
Yes they will all work.. | Excellent
05-25-2012, 08:32 PM
#18 | | Legacy Member
Iowa City, though you'd spend more on gas than the repairs cost lol
05-25-2012, 08:54 PM
#19 | | Registered User
| Quote: |
Originally Posted by jimmy_beaner Iowa City, though you'd spend more on gas than the repairs cost lol | Haha yea true true
05-25-2012, 09:01 PM
#20 | | Registered User
| Quote: |
Originally Posted by Venomouz831 I slept over at my girls house last night. And my car alarm went off at 6 in the morning and when I run out to see what it is no one was there I turn off the alarm and check the car looks fine. When I open the door I realize someone tried to break in and damaged my window. Here are some pics I'm so fricken mad i can punch someone! Is it fixable or do I have to get a new one?
| Good thing you have an alarm
05-25-2012, 10:26 PM
#21 | | Registered User
| Quote: |
Originally Posted by lBRAlD
Good thing you have an alarm | Yea I knw but I really don't have nothing of value inside my car. Stock everything except my sparco seats. N only my backpack was showing
05-26-2012, 04:44 PM
#22 | | Senior Member
| Quote: |
| Alright first off I'm sorry to hear this. just get the seal too the weather strip it might be like 109$. Find it at a local collision center or latemodelrestoration.com.
The seal is simple to change. Snaps right in.
05-26-2012, 06:17 PM
#23 | | Loc: Austin,TX
****ing amateurs.......that sucks. Did you try a salvage yard?
---Dan--
2011 5.0 6MT Black on black premium,3.73 option and some go fast goodies!
*POSTING RULE #1*
Before you post a question, use the forum search feature to determine whether your topic has already been covered. http://www.mustangevolution.com/foru...ork&page=rules |
05-26-2012, 06:18 PM
#24 | | Senior Member
| Quote: |
Originally Posted by DDTCM ****ing amateurs.......that sucks. Did you try a salvage yard? | Screw a salvage yard. Get the real deal.
05-26-2012, 06:40 PM
#25 | | Loc: Austin,TX
| Re: Tried to break in car! Quote:
Originally Posted by Blackedout Screw a salvage yard. Get the real deal. | That all depends what kind of budget you are on but yes the real deal is better.
---Dan--
*POSTING RULE #1*
05-26-2012, 06:49 PM
#26 | | Senior Member
| Quote: |
That all depends what kind of budget you are on but yes the real deal is better. | Yeah you got that right. money talks
05-26-2012, 08:56 PM
#27 | | Registered User
| Quote: |
Screw a salvage yard. Get the real deal. | How is a salvage yard not the real deal??? Stock glass out of a stock mustang at cheap price?!?!??
05-26-2012, 09:28 PM
#28 | | Loc: Austin,TX
Originally Posted by 2002VertGT How is a salvage yard not the real deal??? Stock glass out of a stock mustang at cheap price?!?!?? | I agree but would do a new one if funds were available.
---Dan--
*POSTING RULE #1*
05-26-2012, 10:11 PM
#29 | | Registered User
| Quote: |
I agree but would do a new one if funds were available. | I still don't understand...y buy new?? It's glass, it doesn't wear, the sides don't pit (unless maybe you live in sand storm areas), get a junk one and some windex and install that shiot! No reason to waste $ where it's not needed.
05-26-2012, 10:40 PM
#30 | | Registered User
| Quote: |
Originally Posted by DDTCM ****ing amateurs.......that sucks. Did you try a salvage yard? | No haven't had time n I'm low on money since I just ordered my wheels
05-26-2012, 11:41 PM
#31 | | Loc: Austin,TX
Originally Posted by Venomouz831 No haven't had time n I'm low on money since I just ordered my wheels | You can check online. Since you are low on money go with the salvage yard,you can find some good deals and some places will install the part for you at a decent price.
---Dan--
*POSTING RULE #1*
05-26-2012, 11:51 PM
#32 | | Registered User
| Quote: |
You can check online. Since you are low on money go with the salvage yard,you can find some good deals and some places will install the part for you at a decent price.  | Ok thnks will do sometime next week. Ima have to retint it as well i might as well do limo tint the whole car
