Don't you hate this... - Mustang Evolution
Old 02-12-2008, 11:48 AM   #1
Y2E0L0L5OGWT's Avatar
Every general purpose automotive shop does this and it really pisses me off...If there is any nut, bolt, screw, etc. that needs to be tightened, just about EVERY shop uses an air gun to tighten them...and when they tighten them, they never adjust the torque settings, and they just crank them down as tight as that impact wrench will tighten them...Forget about the typical 50-100 ft-lb factory specs, they will torque anything they can down to 200, 300, hell even beyond the material limits of torque...
/rant
I bring this up because I had put on my new Koni adjustables over the weekend and took it to a shop to get the alignment done so i could get some negative camber (which I was able to get -1.5 degrees, woot!!!!)..In there alignment process, they, as usual, used an air gun to tighten down the nuts that hold the upper strut plate to the car's body in the tower....well, guess what, they torqued that bastard down beyond believe to the point that it sheared the stud completely in half...He went beyond the point of stripping, spinning, bending the stud...it just twisted completely in two...woohoo!!!
I was driving it home and it started rattling real bad...when i got into the driveway, i popped the hood and say that one of the 4 studs in the plate on the drivers side was gone...so i went back up to the shop and he admitted what happened and he put in a new stud free of charge...it was too late in the day or he would have put in a whole new OEM strut plate, but he couldnt get any from anywhere as it was 330 on a saturday afternoon, but he said that if i wanted the whole thing replaced in the future, that he would do it...so he was cool about it...
but that still pisses me off to no end that every shop everywhere does that same thing with the air impact wrenches...I see wheels studs get spun all the time with shops just torquing the hell out of lugnuts...and I know it has happened at least once to majority of the people on here, so i am sure you hate it too...
Old 02-12-2008, 12:18 PM   #2
wiarumas's Avatar
Re: Don't you hate this...
shops are such crooks. it seems that if you dont have a personal connection, they are willing to screw up your car while raping your pocket.
Old 02-12-2008, 12:32 PM   #3
Wait wait wait...he didn't tell you about it when you picked the car up??? I smell a crook...
Old 02-12-2008, 12:46 PM   #4
I am not sure if he knew that he did it at the time or not...I brought the car back up there and he was like "oh, the stud must have cracked and broken off, and I didnt see it"...my guess is that he felt/saw the stud splitting and he was hoping that it would brake off sometime later so that i wouldnt notice or he wouldnt have to fix it...but the stud was definitely sheered completely off...you could see the jagged marks where is had been completely twisted in two...the base of the stud where it broke off was still peaking through the mounting hole...
Old 02-12-2008, 01:34 PM   #5
Herbstang's Avatar
Damn That sucks
Old 02-12-2008, 03:27 PM   #6
That sucks! But not all shops are the same And not all mechanics are monkeys! I believe that you should treat a mechanic like you would a doctor.First make sure you have a good buisness relationship with him or her,that way you won't feel like they're taking advantage of you.Second,when you Do find a good mechanic,stick with them!!! The best customers are repeat customers.Often It's the customer that trys to play "lets make a deal" when it comes to prices of repairs & most mechanics HATE that.You wouldn't ask your doctor if he could do that surgery you need for less then he told you it would cost would you??? I think not. And third,if you do think that he or she IS trying to "screw" you
GET A SECOND OPINION!!! There are more good honest mechanics out there then there are ripoffs. You can't stay in buisness for long if you don't practice honesty.
Truth is Truth whether YOU believe it or not:)
www.bigdmustangs.com
mustero is offline   Reply With Quote
Old 02-12-2008, 03:44 PM   #7
oh i agree completely, there are good and bad mechanics/shops out there...i am not saying that this place was a bad shop (they were recommended by someone), but my point is just that they need to quit tightening every bolt, screw, nut down so damn tight with air compressed impacts wrenches...it's a pet peave for mine to torque a bolt down to some ungodly amount to where you cant event get it off with a big *** breaker bar when the factory spec for the bolt was only 75 or 100 ft-lbs...
All shops use those air guns to tighten stuff down because it saves time which I understand, but there is no reason on earth to torque them down so much...thats what pisses me off...not the quality of their work...I am very picky about my mechanic too, and I do most work myself if and when I have the time to do so...but like i said, my gripe isnt with good or bad shops, its just that all shops good and bad over-torque things to a ridiculous degree and that irritates me...
I hate Jesse Jackson. I hate him. Hate him hate him hate him! Brent The Bar 16 05-14-2007 05:37 PM
hate to be her Warfire80 The Bar 6 05-30-2005 08:30 PM
i hate..... MusclesFromBrussels The Bar 31 08-02-2003 06:03 PM
03:33 AM
