Figured my setup out... - Mustang Evolution
Old 11-18-2003, 12:48 AM   #1
Tbird232ci's Avatar
i finally figured out the setup i wanna run when i build this 5.0
im keeping the stock heads, but im gonna port em to hell, and unshroud the valves, and run trick flow springs, then pick up a trick flow #1 cam, im gonna try to run some long tube headers if they clear the shifter, and probably grab an intake manifold off of ebay, one of those edelbrock wannabe's
if i do a good job on the heads, i could probably see 275-300hp at the flywheel, and maybe about 350-360ftlbs or torque
any input?
Old 12-11-2003, 09:43 AM   #2
RGR
Send a message via AIM to RGR
HP will be closer to torque, 1 HP/ci is not hard with stock 5.0 heads...
I got ~55% increase in exhaust flow on a D8 (junkiest 5.0 heads ever)
with the stock valves... I have a die grinder and porting stuff FS
if U need something to port it with.
http://v6stangs.addictgamers.com/viewtopic.php?t=3683
I can also help you with porting those babies, I cut my teeth on 5.0 stuff!
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
I figured we can help a sponsor out.... Brent The Bar 11 06-21-2006 12:23 PM
Figured out the Integra troublecode 232SCstang The Bar 6 07-12-2005 02:06 AM
Figured i'd post some pics of my pets too sonic04edge Pictures and Videos 11 04-27-2005 09:06 AM
Check out the pics now figured it out Matt'sredbeauty The Bar 19 01-19-2005 10:26 PM
04:27 PM
