2012 Mustang V6 Specs. **Interesting** - Mustang Evolution
Old 02-15-2013, 07:34 AM   #1
Here are the specifications on the 2012 3.7 Mustang.
Old 02-15-2013, 07:46 AM   #2
UltArc's Avatar
Originally Posted by ronnie948
Here are the spedifications on the 2012 3.7 Mustang.
O H
2012 Mustang EPA: 19/29
2012 AeroStang: 40/46
My sponsor, Tokkyo Nutrition, offers 50% off your entire order with the code "PowerHouse"
UltArc is offline   Reply With Quote
Old 02-15-2013, 02:24 PM   #3
aegischief's Avatar
It's not accurate. It's says the motor takes five quarts, it really takes six. And my 2012 automatic came standard with the 2.73 gear ratio. Just saying.
aegischief is offline   Reply With Quote
Old 02-15-2013, 03:48 PM   #4
You are correct
It does take 6 quarts of oil.
My car is so responsive I'm pretty sure it has the 331 ratio gearset. How can I tell for sure? Mine is also an Automatic.
Old 02-15-2013, 03:53 PM   #5
aegischief's Avatar
My gear rations listed on the window sticker and dealer invoice. You can also check the driver door, I believe there is a code there for the gear ratio.
I also thought that autos only came with 2.73 gears and manuals could upgrade to 3.31 as a one off option or through the performance package which isn't available for autos.
Old 02-15-2013, 04:01 PM   #6
aegischief's Avatar
I was wrong. The window sticker did not indicate anything on gear ratio. It was listed on the dealer build invoice though. The showroom mustang guide lists the 2.73 as standard with 3.31 as option (coupe only) so you may have it. The performance package is available on manuals only.
Old 02-15-2013, 05:48 PM   #7
I found the codes
The door jam sticker has the axle ratio information codes:
2011 & 2012
The axle ratios are:
BB - 3.73 ratio, base vehicle with manual or automatic transmission
CC - 2.73 ratio
DD - 3.55 ratio with manual transmission
GG - 3.31 ratio with automatic transmission
YY - 3.15 ratio
Mine say's CC so I do have the 2.73 ratio. As zippy as my car is now I would bet it would really be zippy with a 331 ratio in it.
Old 02-15-2013, 06:57 PM   #8
aegischief's Avatar
Sweet info.
Old 02-16-2013, 07:16 AM   #9
ArtU's Avatar
Seems the 2013 specs are just as wrong about final drive gears:
http://media.ford.com/images/10031/2...tang_Specs.pdf
My build said 2.73 gears when I dug into it now, yet these specs say the optional auto comes with 3.31 gears. I might have to file a compliant and ask for my 3.31 gear set installed I was expecting from this spec sheet
2012 mustang
10:40 AM
