fastest ride of my life... - Mustang Evolution
Old 12-01-2003, 12:00 PM   #1
Send a message via Yahoo to 98GreenStallion
This thanksgiving was a grreat thanksgiving. Getting to see all your family (even the ones you dont like) and all the turkey and dressing you could ever eat! I'm also pleased to say my cousin bought his own 2001 white V6 mustang coupe... Which is for now completely stock except for the subs (600 watt kenwood 10 inch sub with 450 watt amp) Well, my cousins and I took a ride in it, it was fast, although my 5 speed seemes faster, it was fast. And he was crazy. Driving down the public highways and skinny curvy county roads at 115 mph+ was making our trip take no time at all. I was just hoping a deer wouldnt run out in front of us! But it was cool to see the mustang get up to and over 120 in hardly no time at all. We nearly could have recked many times coming up over steep hills and cars being parked on top, if it wasnt for the grand brakes... Over all it was the fastest and maybe even one of the scariest rides of my life...
We also went bowling. I scored a high of 85!!
http://images.cardomain.com/member_i.../402003_35.jpg
Mods: BV heads, cut and weld upper, fully ported lower, 216/225 cam, 1.73 RR's, 60mm TB, 19# injectors, new timing set, 25% UDP, CAI, SCT chip, PCV delete, EGR delete, MAC LT headers, O/R H-pipe, durablack cat-back...
www.rpm-mustangs.com
RDmotorsport
New dyno
193.8rwhp/238.9 rwtq
98GreenStallion is offline   Reply With Quote
Old 12-01-2003, 12:09 PM   #2
tire's Avatar
Send a message via AIM to tire
Bowling is fun, I did that yesterday actually. Going 115 mph is not cool though.
tire is offline   Reply With Quote
Old 12-01-2003, 12:12 PM   #3
Danger Dude's Avatar
I have burried 120 out at the runway every chance I get
Old 12-01-2003, 12:19 PM   #4
tire's Avatar
Originally Posted by Danger Dude
out at the runway
what one?
Old 12-01-2003, 12:32 PM   #5
KrazyPony's Avatar
That would be the Runway at which Corey works at ( Lockheed )
http://i201.photobucket.com/albums/aa307/KrazyPony/KrazyPonysigBlue.jpg
KrazyPony is offline   Reply With Quote
Old 12-01-2003, 12:32 PM   #6
Here in Greenville, SC. I work at the old Donaldson AFB and of the three runways only one is active, one has hangers on it and is the flightline (Parking area) and the other is used by BMW, Michelin and me to test our cars
Old 12-01-2003, 12:33 PM   #7
tire's Avatar
Old 12-01-2003, 12:46 PM   #8
Black95GT's Avatar
Send a message via AIM to Black95GT
Nice
-Jason
2003 DSG Cobra -2.2L KB, 60lbs Injectors, Single Blade TB, SCT2400 MAF, Kook's LT's, Kook's High-Flow Catted X-Pipe, Magnaflow CB, JLT RAI, MGW Short-Throw, H&R Race Springs, MM CC Plates, MM Bumpsteer, BF IRS Brace, BF Idlers, and AFS 18 Chrome Reps w/ R888s
Black95GT is offline   Reply With Quote
Old 12-01-2003, 04:07 PM   #9
I wish I had my own personal runway!! Going that fast alot isnt to good for our motors though is it? Cause at 125 the rpm is at 3500 in 5th... Oh well I am going to practice my drum solo now 8)
RDmotorsport
New dyno
Old 12-01-2003, 08:33 PM   #10
BlueDonkey's Avatar
You should come up here, Corey. Runway over at Pease handles NH Air Guard's refueling wing, and is an emergency landing site for the Space Shuttle
BlueDonkey is offline   Reply With Quote
Old 12-02-2003, 06:58 PM   #11
being bad on the motor is not the problem its killing yoru self or worse some one else thats the problem.
Old 12-02-2003, 08:10 PM   #12
an RPM is a RPM bet it 3,500 in 1st or 5th.
The wear on the engine is the same.
The most damge occurs during acceleration from a standstill. That is what is hard because it causes stress on the entire vehicle. The drivetrain (engine back) most of all.
Extreme Effects.com is offline   Reply With Quote
Old 12-03-2003, 12:10 PM   #13
Finally, someone else going over 120 in stock 99+ stang. People told me that it couldn't be done and that I didn't do it. At least someone else can attest to the fact that they'll do it and do it well. But alrighty, cool job man. Gotta love stangs at 120+
Old 12-03-2003, 02:06 PM   #14
Not calling you a liar... But I've taken my stang to 120 a few times and at 120 the fuel pump cuts out and the car just sort of loses power until it slows down and the pump turns back on... I thought the governor wasn't for speed, but for RPM in fifth gear...... So maybe it's because I have an auto and my RPMs are higher in final gear or something though...
Laser02 is offline   Reply With Quote
Old 12-03-2003, 02:38 PM   #15
Well when you are attempting a high speed run take it out of overdrive. I just ran down the runway 30 min ago and once again buried the speedo. sure wish V6 cars had better speedos
Old 12-03-2003, 06:13 PM   #16
Well the speedo only goes to 120... And from what I heard the governor is at 118... So you can pretty much hit 120... But past that? There's a little peg that blocks the needle.. So how do you know your speed? And our speedos are not accurate over 100... So...
Old 12-03-2003, 06:46 PM   #17
well with a chip you remove the limiter and the fastest I have gotten to was 136 with a 03 cobra besides me. Actually the fuel does not cut out. At 116 the computer shuts down 3 of the cylinders from firing. Fordchip disables that if you want like on mine
On another note a MD Dyno is a 1 to 1 dyno It can caliberate weight of the car and wind resistance and get you a very accurate speed reading while making a dyno run
Old 12-03-2003, 06:53 PM   #18
Zim
You want to **** me?
Zim's Avatar
i thought ball bearings were sucked down to the fuel pump to block off the fuel lines and thats why it shuts off. Im pretty sure its a fuel pump thing.
I like toys
Old 12-03-2003, 06:59 PM   #19
well how would the computer control that unless it is controlling the vacume. the fact is the fordchip eliminates the speed control. The ball bearing thing is warped it is easier for the computer to shut off the injectors
Who has the fastest car on this board? red herring The Bar 79 05-01-2007 04:37 PM
Who has the fastest car on the board? lthlsnake The Bar 23 05-11-2006 10:17 AM
whats the fastest you have ever been in your car..... Brent The Bar 55 05-16-2004 02:46 PM
Fastest car youve ever driven? Tbird232ci The Bar 34 04-28-2004 01:54 PM
Fastest New Outlaw Racer.... KrazyPony The Bar 4 01-26-2004 06:22 PM
08:19 AM
