Are you a down shifter or a coaster? - Mustang Evolution
Old 05-29-2014, 06:34 AM   #1
Grimace96's Avatar
Red light, stop sign, turning left and right, traffic jams, slow *** tractors, I can't help it. I'm a downshifter. Not obnoxiously...ok maybe sometimes. But I know a lot of coasters. Which method of stopping tickles your pickles?
Grimace96 is offline   Reply With Quote
Old 05-29-2014, 06:40 AM   #2
irishfan's Avatar
Coaster. Brake pads are cheaper than a clutch
Sent from my SPH-L900 using Mustang Evolution mobile app
irishfan is offline   Reply With Quote
Old 05-29-2014, 06:43 AM   #3
Grimace96's Avatar
Pfsh. All four of my brake pads combined are nearly $500. Any time I've ever changed my brake pads I do all of them.
Old 05-29-2014, 06:51 AM   #4
irishfan's Avatar
Someone saw you coming from a ways away
Old 05-29-2014, 06:57 AM   #5
Grimace96's Avatar
You'll hear me before you see me lol
Old 05-29-2014, 07:00 AM   #6
Sterlingbeast5.0's Avatar
Both. I coast allot but downshift turning usually... OR if I am in the mood to hear the sweet gurgle of the exhaust from the downshift!
Old 05-29-2014, 08:22 AM   #7
13BKV6's Avatar
i coast way more than downshifting. but that may change once i install my axlebacks...
Current: 2015 GT Premium Performance Package-stock for now
Past: 13 V6, 11 MCA V6, 89 GT, 88 GT, 04 V6
13BKV6 is offline   Reply With Quote
Old 05-29-2014, 09:22 AM   #8
Cobra mark's Avatar
I down shift id say 90 percent of the time it just comes natural it was how I was taught
Old 05-29-2014, 09:24 AM   #9
13BKV6's Avatar
whats the major advantages/disadvantages of each?
i pretty much learned to drive a stick on my own, and i would def. like to preserve tranny/clutch as much as possible.
Old 05-29-2014, 10:02 AM   #10
Grimace96's Avatar
My dad used to tell me (not saying this is true, because I honestly don't know) that skipping gears isn't good for the transmission. But like I said, don't hold me to that. I, too, would like to know if there are disadvantages to downshifting all the time.
Old 05-29-2014, 10:28 AM   #11
Ish416's Avatar
If you use engine braking, just make sure to rev-match when you down shift. No worries.
Now, if you are driving and just start dropping gears without blipping the throttle, that could eventually cause issues.
I always rev match a down shift. It's something I have done since before I had my license, racing quads and bikes to prevent the back tire(s) from locking up. It's just common sense.
As for skipping gears, it's perfectly fine. Some cars even have skip shift for better fuel mileage. My Z28 had a 1-4 lock out if you weren't getting on it. So just taking off normally in first, 2nd and 3rd would be locked out and 4th would be available. I would always drive it in 2nd and 5th in town, or go 2nd to 6th. Sometimes even 1st to 6th getting on the highway.
In my Mustang, I usually just go 1,4,6 getting on the highway.
When doing this, you also need to rev match, otherwise you will be giving the synchros a hard time and they will then fail prematurely.
Old 05-29-2014, 11:37 AM   #12
I rarely engine brake. I would much rather replace my brake pads than my clutch, even though I need to replace all of that fairly soon.
The times I do downshift and engine brake are on steep downhills, but then I'm also on the brakes, not just the engine. I do a lot of city driving when at home in Sacramento so I coast a lot with the clutch in.
Old 05-29-2014, 11:45 AM   #13
Grimace96's Avatar
I thought coasting with the clutch in was a bad thing? That doesn't wear down the clutch?
Old 05-29-2014, 11:51 AM   #14
I love the sound of down shifting almost as much as accelerating
Old 05-29-2014, 12:26 PM   #15
13BKV6's Avatar
i thought the same???
Old 05-29-2014, 12:30 PM   #16
Clutch in or in neutral. It depends on if I can tell if the light is going to change soon.
People say that coasting with the clutch in wears out the throw out bearing faster. But let's be real, what Mustang doesn't already have a crappy throw out bearing that needs replacing?
Old 05-29-2014, 01:07 PM   #17
It's not me, it's you.
primer2tone's Avatar
Depends on how much I've had to drink.
Old 05-29-2014, 01:25 PM   #18
Grimace96's Avatar
Trees count too I guess hahaha.
---------- Post added at 07:25 PM ---------- Previous post was at 07:24 PM ----------
Not mine!!! Considering I just replaced it lol
Old 05-29-2014, 06:42 PM   #19
UltArc's Avatar
I was always taught no clutch wear if it is 100% OUT or 100% IN. But if your foot is not completely off or completely on, there is wear.
I EOC to coast, engine brake for braking.
Sent from my XT1049 using Mustang Evolution mobile app
2012 Mustang EPA: 19/29
2012 AeroStang: 40/46
My sponsor, Tokkyo Nutrition, offers 50% off your entire order with the code "PowerHouse"
UltArc is offline   Reply With Quote
Old 05-30-2014, 06:05 AM   #20
FullyAutomatic's Avatar
Region: Mexico
everytime I drive a standard car I put it in neutral and coast then just pick the gear for my speed when I need to accelerate...
I used to drive truck for a while... after double clutching forever you tend to just want an auto
FullyAutomatic is offline   Reply With Quote
Old 05-30-2014, 06:06 AM   #21
Grimace96's Avatar
That just takes all the fun out of the manual though
Old 05-30-2014, 09:31 PM   #22
Getn off's Avatar
True, if the clutch is all the way in, the clutch disc is not touched, hence no wear. Problem with coasting to a stop is that if an emergency situation arrises, you might just have kissed ur last option goodbye. Every race school will advise u not to coast to a stop for this reason. But, to each his own.
Troy
Getn off is offline   Reply With Quote
Old 05-30-2014, 09:38 PM   #23
Sportsman's Avatar
I downshift... Dad always told me save your brakes and it's stuck
Sportsman is offline   Reply With Quote
Old 05-30-2014, 10:12 PM   #24
Loc: Austin,TX
Downshifting dip****.....
Mustang downshifts into guard rail - YouTube
Old 05-30-2014, 11:18 PM   #25
Getn off's Avatar
Originally Posted by DDTCM View Post
Dip****, yes! But, Looks more like he upshifted and spun to me. Funny, none the less.
Troy
Old 05-30-2014, 11:25 PM   #26
Region: Mexico
lol drive a 18 speed for a year or two everyday.. double clutching.. splitting gears pre selecting, hi/low ugggh... and the "fun" in manual is all gone and becomes just annoying..
Old 05-31-2014, 12:15 AM   #27
PonyBoyV6's Avatar
I'm a hybrid of the two. I'll coast any time i know i'll be coming to a complete stop. But having lived in this area all my life, and traveled much the same routes countless times, you can kind of get a feel for the traffic timers. So if i feel the light is going to turn before i get there, that's when i like to downshift. Like others said. i'd much rather replace my brake pads.
PonyBoyV6 is offline   Reply With Quote
Old 05-31-2014, 04:16 PM   #28
Mile high JDF's Avatar
I rev match and downshift and then decide if I need to hit the brakes from there. It's a habit born from racing
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 06-02-2014, 09:00 AM   #29
Are they made out of gold? COBRA rotors/pads are under $200 from Rockauto and that's for really good ones. Someone sure took you for a ride... wow...
Even if it was $500 for brakes that's still cheaper than a clutch and if you are DIY its a ****ton easier too.
Old 06-02-2014, 04:36 PM   #30
samuelsmith's Avatar
Kick....push....coast I have been a coaster since back in the day.
Old 06-02-2014, 06:31 PM   #31
Grimace96's Avatar
Platinum actually. That was the cost of all 4 sets of pads, all rotors. The brake pads alone were $115/set. Like I said before, I'm not taking shortcuts with this car. He's had too many already. I watched him get ripped apart yesterday and I just stood there shaking my head for a good 3 hours. People think I'm insane for doing what I'm doing, but it'll be worth it once he's finished. He's got a long way to go before I'll be satisfied. And I'm gonna make sure he has the best of the best of everything that goes in him.
Do they make gold ones? Purple and gold look like royalty, and to me, he's totally royalty lol.
Old 06-02-2014, 07:11 PM   #32
Lol, I'd say its more of an eggplant
Old 06-02-2014, 07:33 PM   #33
Downshifter. I love rev matching downshifts and the burbles and pops you get from the exhaust when rolling to a stop in gear. Though I'll agree, brake pads are cheaper then a clutch.
BadCon is offline   Reply With Quote
Old 06-03-2014, 12:49 AM   #34
ColeJohnson's Avatar
I use brakes... I'll go into neutral when I coast.
It only takes a half second to pop it back into gear if I need to. Whoever was saying you might have exhausted your last option by taking it out of gear to coast and brake should really consider thinking ahead in traffic and being cautious of other drivers.
That being said- in traffic I'm usually never stopping so I stay in gear and shift up or downshift as needed to stay in the proper rpm band.
2016 Comp Orange GT (current)
Old 06-03-2014, 05:37 AM   #35
Grimace96's Avatar
Hahahaha. That's a new one!!!!
I am writing and novel, will you tell me what you think? Don't water it down.? hassin General Mustang Discussion 5 03-04-2010 12:07 AM
shifter linkage on a toploader with hurst shifter gardgriff24 Classic Mustangs 7 03-02-2009 10:34 PM
Any roller coaster fans? I rode a SWEET coaster today fast64 The Bar 20 03-05-2008 09:32 AM
Roller Coaster Tycoon Massacre Brent Pictures and Videos 14 02-21-2008 12:08 PM
05:38 PM
