Problem installing Winxp - Mustang Evolution
Old 12-30-2003, 03:46 PM   #1
I am trying to reformat my computer and install Winxp and redhat and suse on it
but when i put in the winxp cd and it boots up to the cd it goes thorugh the process of loading all the nhardware crap and then it gives me the option to choose to reapir or install new windows.... when i hit install fresh windows it gives me a blue screen that says Stop: and goes on to give a error about Nopage something or god knows
Why wont it let me install it! :
Old 12-30-2003, 05:08 PM   #2
Dom
Dom's Avatar
Send a message via AIM to Dom
I've installed mine like 5 times. Never happened to me.
Old 12-30-2003, 05:44 PM   #3
Send a message via AIM to heramb22 Send a message via Yahoo to heramb22
You might want to use the fdisk program on the Linux cd to partition your harddrive to the sizes you want for each OS, then install the linux first. Later when you install the XP put it on the partition that you made for it.
If you do it this way you can use GRUB or LILO (boot loaders) to control which OS you boot into. check out http://en.tldp.org/HOWTO/LILO.html
I'm just recalling this stuff from the one time I did it about 2 years ago, so I'm sure things have changed (gotten easier since then) and I know I've forgotten a lot.
http://www.heramb.net/pictures/Stang/dan_sig.jpg
http://www.heramb.net/pictures/Stang/billet/
Parts for Sale VERY CHEAP!
SOLD - White Cobra rims, rear GT swaybar, ASP UD pulley, cleared headlights, full-length Densecharger, red calipers, MustangWorld billet grille, true dual exhaust w/ flowmaster 40's, MAC lowering springs (front), raised gas pedal, MSD 8.5mm spark plug wires, GT foglights, Steeda Tri-ax
heramb22 is offline   Reply With Quote
Old 12-30-2003, 06:06 PM   #4
http://support.microsoft.com/default.aspx?scid=kb;en-us;315335#appliesto
That is the error I am getting.
The Page Fault in non paged area stop error when trying to get into the winxp installation
Old 12-31-2003, 06:56 AM   #5
KrazyPony's Avatar
Brent I may have a util for you that will work, its very similar to fdisk, but is called GDisk. I should have it tonight with the switches and command line you need to use to delete that pesky ole HD of yours!
http://i201.photobucket.com/albums/aa307/KrazyPony/KrazyPonysigBlue.jpg
KrazyPony is offline   Reply With Quote
Old 12-31-2003, 08:21 AM   #6
cool let me know when you get it
Old 12-31-2003, 09:37 AM   #7
BlueDonkey's Avatar
According to the error, XP doesn't like your RAM. If that's true, you can partition it all you want, but it ain't gonna matter.
BlueDonkey is offline   Reply With Quote
Old 12-31-2003, 10:50 AM   #8
Its not my ram. There is no way I can have two bad memory sticks just like that. It worked fine before I tried installing Linux. I dont think I partioned the linux from the windows correctly.
Old 01-02-2004, 06:42 PM   #9
it reformated mine took forever.... but it worked.
installing new 3.73 gears jk7208 1996-2004 Mustang GT 7 06-20-2009 10:38 PM
Installing Suspension bluemustang 1979-1995 Mustang GT 16 04-13-2005 06:56 PM
Installing my SC soon Danger Dude Pre-2005 V6 Mustang 11 02-11-2004 08:48 PM
Installing a CD Player in a 90 GT ItWouldAppearSo Mustang Audio & Video 3 01-13-2004 05:18 PM
installing Studlystang921 Pre-2005 V6 Mustang 1 08-23-2003 09:11 AM
04:40 PM
