How can you keep your laptop cool? - Mustang Evolution
Old 01-13-2004, 12:14 PM   #1
Monkey's Avatar
Today i was on my bed surfing the net and talking to people and my laptop just shut off. i first thought it was a virus, but then i tried to start it back up, and it would try, then cut off again. it did this multiple times until i let it cool for 5min and now im back on it. i guess it has a problem getting really hot because other times, my computer starts to lag a lot when it gets hot too and i know its over heating.
so, are there any things i can buy for my computer to keep it cooler? its not overclocked or anything, so i figured the stock fan would keep it fine. btw, its a dell inspiron if that matters
Old 01-13-2004, 12:17 PM   #2
thats pretty bad if its overheating like that and its a new laptop.
Laptop aftermarket parts are pretty much limited. You could try looking for a higer rpm case fan. It might actually be a problem with your cpu fan not working properly if its overhaating. Is it under warranty?
Old 01-13-2004, 12:26 PM   #3
Danger Dude's Avatar
They make a cooling pad or plate that has fans built in it and you place the laptop on it Here you go Brandon http://www.mrtechus.com/notcoolpad60.html
You can also go to pricewatch.com and look under notebook accessories and find pad coolers
Old 01-13-2004, 01:03 PM   #4
Fishers Stang's Avatar
yeah Corey had it right, the pad, if its brand new, take it back have them look at the CPU fan, and the fan in the back. my PC i have 3 fans + the stock one.
Charles
Old 01-13-2004, 04:46 PM   #5
Zim
You want to **** me?
Zim's Avatar
if it was on your bed or somethin the fan hole could have been covered and the heat couldnt get out... maybe?
I like toys
Old 01-13-2004, 04:54 PM   #6
KrazyPony's Avatar
I would go with our drunken son Zim here on this one, my wife has 1 aswell and if its sitting on a pillow it gets very hot since the air cant escape at all, but once she places it on a board and uses that it is fine....
No Escape of Air = CANT BREATH...CHOKE CHOKE CHOKE... NOT GOOD!!!
http://i201.photobucket.com/albums/aa307/KrazyPony/KrazyPonysigBlue.jpg
KrazyPony is offline   Reply With Quote
Old 01-13-2004, 04:56 PM   #7
Dom
Dom's Avatar
Send a message via AIM to Dom
That doesn't work on an engine. It finds a way to breath.
I'm also going with Zim. :yes:
Old 01-13-2004, 04:59 PM   #8
KrazyPony's Avatar
You thinking about a Turbo arent ya!
Old 01-13-2004, 05:04 PM   #9
Dom
Dom's Avatar
After tallying up the needed parts, Zex Nitrous is a better choice. :thumb2:
Old 01-13-2004, 05:15 PM   #10
Zim
Zim's Avatar
go with NX
I like toys
Old 01-13-2004, 06:41 PM   #11
Monkey's Avatar
it may have been resting on my leg, (i was sitting with it in my lap watching tv)
however, i put it on my desk and ran Disk Defrag cause it needed it. when i came back from class, my computer was off. it was plugged in and everything. it has been doing that for the past 2-3 days. someone on 3.8 said his friend has an Inspiron and it is under warrenty (as is mine) and needs a new motherboard.
think i should buy the cooling pad first, and then call dell if it is still acting up?
Old 01-13-2004, 06:44 PM   #12
Zim
Zim's Avatar
id say just call dell. Dont waste you money on other things that probably isnt the problem. Id say take advantage of your warrantee while youve got it.
I like toys
Old 01-13-2004, 06:45 PM   #13
Zim
Zim's Avatar
also maybe install some desktop tools that allow you to see the temperature of your CPU, case, and other things. Shahrum knows of one that he used on this server. Your computer shouldnt be any higher then around 55-60* celcius
I like toys
Old 01-13-2004, 07:30 PM   #14
BlueDonkey's Avatar
that would be my advice. you've paid for support; now put your money to work.
BlueDonkey is offline   Reply With Quote
Laptop? Thomas91169 The Bar 21 04-16-2008 01:37 AM
New Laptop Seph The Bar 26 03-11-2008 11:22 AM
Need help with laptop I_luv_HP&trq The Bar 7 01-08-2007 04:40 PM
So I need a new laptop STEVE The Bar 15 07-29-2006 10:11 PM
some laptop help jimmy_beaner The Bar 8 10-02-2005 11:57 AM
11:22 AM
