change the fuse box cigarette lighter to turn off - Mustang Evolution
Old 01-24-2004, 01:14 PM   #1
Send a message via AIM to mexor
i have a GPS that plugs into the cigarette lighter adapter. in all my other cars, i turn the car off, the gps turns off. in the mustang, i turn the car off, the gps stays on
how can i change the fuse box so that the gps turns off when i turn the car off. i think this is possible, and wouldn't be too hard.
charles..you may have to help me on this one ...
-dave
mexor is offline   Reply With Quote
Old 01-24-2004, 03:11 PM   #2
Not much you can do...most fords do this, at least my ranger and most other vehicles I've been in from ford. just something about fords. It just keeps the cigarette lighters and other plug ins on, on how to fix it...you could run an alternate plug somewhere else in your car by plugging into something that cuts off when you cut your car off...I'll think on this for a little bit, do some experimenting and try to figure out what
Old 01-24-2004, 07:56 PM   #3
Dom
Dom's Avatar
Send a message via AIM to Dom
People have hardwired radar detectors. I'm sure you can do they same. [http://fnsweet.com/garage/radar/index.shtml]
You could always buy another adater, and run a wire from the battery and turn it on and off with a switch.
Old 01-24-2004, 08:48 PM   #4
i actually can't cut the wire ..because at the end of it there is a speaker that tells you how to get places ...so i want to modify the cigaratte lighter adapter in the fuse box ..
Old 01-24-2004, 10:15 PM   #5
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
hmmm...
i might beable to hook something up for you, ill have to steal soemthing from work. But i have an idea.
But not anytime soon, its freezing.
Rellik is offline   Reply With Quote
Old 01-25-2004, 12:08 AM   #6
Send a message via AIM to Hockeyb0y3
i have the opposite prob, i can't get eather of my lighters to work, the light comes on in the on next to the e-brake but not the lighter the one with the flip door wont work eather, i checked the fuses but couldn't find the bad one . . . .unless theres a nother fuse box i dunno about, i didn't get the owners manual when i bought the car, im the 3rd owner and the first owner lost it . . .. help?
Martin
Hockeyb0y3 is offline   Reply With Quote
Old 01-25-2004, 12:11 AM   #7
BlueDonkey's Avatar
you have 3 power ports?
BlueDonkey is offline   Reply With Quote
Old 01-25-2004, 01:35 PM   #8
charles ..what is your idea? ..ive never messed w/the fuse box of the mustang, but on my 240sx i had the best buy ppl wired my amp to a live connection so it was alwyas on , i switched it with the cigarette lighter (which turned off when the car turned off) and i just didn't use the cigarette adapter.
also another idea was someone said at autozone they have a adapter -> positive/negative cord. that might work if you wire it to the ignition.
no rush though, how about we do it when the temperature gets to the mid 60s
Old 01-25-2004, 01:40 PM   #9
Shahrum's Avatar
Send a message via MSN to Shahrum
Thanks Dom for the link to that article... this morning I hardwired my radar detector finally I ran it into the power supply for my Sony headunit.
Shahrum is offline   Reply With Quote
Old 01-25-2004, 03:10 PM   #10
tire's Avatar
Send a message via AIM to tire
Martin
i'll check which fuse it is for you soon, i am moving rightnow, give me a day or so. and maybe remind me. the fuse box is under the steering wheel.
tire is offline   Reply With Quote
cigarette lighter trouble w_nixon Pre-2005 V6 Mustang 18 03-20-2010 08:20 AM
02:07 PM
