need pc help - Mustang Evolution
Old 03-08-2004, 04:58 PM   #1
Thomas91169's Avatar
need pc help
pc specs
dell dimension 2400
2.6 intel processor w/533mhz front side bus
512mb ram
80gig hd
i have this stupid problem that pisses me off. whenever i dont do something internet related for like a minute, and then i try to use the net, it takes about 30 seconds to a minute for it to do something internet related. i have sbc yahoo dsl.
heres an example. when i start my computer, the first thing that tries to happen is msnmessenger tries to open my mail automatically on startup, but fails. i open up a explorer window, and it does nothing for about 30 seconds, then it loads it fine.
another example. when i write long replies to posts on forums, and i dont dl any info while im typing, then i go to "send" or post the message, it takes about 30 seconds to start sending anything, or it goes to the all powerful white error screen. which then i press refresh and it loads fine.
we have a home network with 3 other pc's and they dont have this problem, just me, and i have the best pc. anyone got any ideas?
-Thomas-
Old 03-08-2004, 05:03 PM   #2
BlueDonkey's Avatar
a) describe your home network
b)how long has it been doing this?
BlueDonkey is offline   Reply With Quote
Old 03-08-2004, 05:08 PM   #3
well first off try turning off msn messanger.
Then make sure you have ran Windows Update and downloaded all the security updates atleast
To turn off MSN Messanger:
Go to your Control Panel, Add/Remove Programs, Add Remove Windows COmponents and scroll down to MSN Messanger and uncheck it.
Old 03-08-2004, 05:10 PM   #4
home network is a cisco systems lynksys cable/dsl router. it did it when we didnt have the network, and it was just my computer hooked up, then i started streaming techno constantly whenever i was online, and it stopped(cause i was always recieving info) then i stopped streaming and its back now. my dad thinks its the mass amount of mp3's i have, all whopping 90 of them. i had 560 on another pc and it was older and didnt do this. ive checked the cat5 connections all through the house to make sure they were copa setic (dad put them together) and they looked fine to me. could it be something software related on my pc?
-Thomas-
Old 03-08-2004, 05:12 PM   #5
and it did this after a fresh install of windows? When do you remember it starting
Old 03-08-2004, 05:12 PM   #6
all security updates are installed, unchecking msn messenger now..............
wait wont that delete it?
i just made msn messenger so it doesnt start on startup.
-Thomas-
Old 03-08-2004, 05:13 PM   #7
no it wont delete it... if you need it back just check it again and it will load it up.
Old 03-08-2004, 05:14 PM   #8
ah brent you remembered. yeah it did it before too, i thought i had some sort of spyware or crap that made it do that, along with other symptoms, thats why i reinstalled and reformatted. but it still does the 30 second idle thing. it just pisses me off, really annoying. it runs fine the rest of the time.
-Thomas-
Old 03-08-2004, 05:15 PM   #9
shyt i just got called into work, ill be back later tonight. you guys are the bomb yo.
-Thomas-
Old 03-08-2004, 05:52 PM   #10
Smells like DNS issues.
Laser02 is offline   Reply With Quote
Old 03-08-2004, 06:08 PM   #11
KrazyPony's Avatar
needs to look at your event viewer, that will give you a event id and then you can research it.
just right click on my computer
choose manage
and then event viewer from the left hand side
and look at system events.
You should be able to locate a error there and pin it down that way, you can enter the error in google to find out what it means that way.
Good luck!
http://i201.photobucket.com/albums/aa307/KrazyPony/KrazyPonysigBlue.jpg
KrazyPony is offline   Reply With Quote
Old 03-08-2004, 08:36 PM   #12
aaaaah this makes sense
The IP address lease 192.168.1.101 for the Network Card with network address 000BDBB2ADCA has been denied by the DHCP server 192.168.1.1 (The DHCP Server sent a DHCPNACK message).
User Action
No user action is required. The DHCP Client service will continue trying to obtain a working IP address until it succeeds, and DHCP establishes the network connection on its own.
i guess now that i know whats going on, it wont really bother me. thanks for the help krazy, brent and donkey.
-Thomas-
Old 03-08-2004, 08:44 PM   #13
BlueDonkey's Avatar
that's an interesting error.... why is the router denying you your address (I'm assuming this is on a lease renew)?
may be a good idea to look at any debug that the router (assuming that the router is the server) gives you.
failing that, maybe a static address is in order?
Old 03-08-2004, 08:53 PM   #14
DHCPNACKs are sent when the IP address is already in use by another computer or the IP address in invalid in accordance with the scope that it's configured with.
It should not be happening every few minutes. Unless you screwed up your DHCP leasing. Default leases are 8 days.. And you will request a renewal when 50% of that expires... Something is not configured right on your DHCP server.
Old 03-08-2004, 08:58 PM   #15
BlueDonkey's Avatar
or the client; the other computers on the network are fine, he says.
GST, can you show the output of "ipconfig /all"?
open DOS prompt
type ipconfig /all > filename
and paste the contents of filename in the forum; I'm curious to see some of these values, like lease time.
Old 03-08-2004, 09:32 PM   #16
Eh... The lease time is a property of the DHCP server. The only thing the client knows is to look for a server every 5 minutes as long as the DHCP is set. :
Old 03-08-2004, 10:18 PM   #17
Windows IP Configuration
Host Name . . . . . . . . . . . . : thomasroom
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadcom 440x 10/100 Integrated Con
roller
Physical Address. . . . . . . . . : 00-0B-DB-B2-AD-CA
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.101
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 64.169.140.6
206.13.28.12
Lease Obtained. . . . . . . . . . : Monday, March 08, 2004 2:16:41 PM
Lease Expires . . . . . . . . . . : Tuesday, March 09, 2004 2:16:41 PM
-Thomas-
Old 03-08-2004, 10:19 PM   #18
now that i htink of it, prolly not smart to put my ip adress on a public forum.
-Thomas-
Old 03-08-2004, 10:21 PM   #19
BlueDonkey's Avatar
it's a private address, anyone tries to do anything with it, they'll get nowhere special.
Besides, you already posted it
Old 03-08-2004, 10:23 PM   #20
ah
-Thomas-
Old 03-08-2004, 10:23 PM   #21
ah
-Thomas-
Old 03-09-2004, 01:42 PM   #22
We can just get it without you posting anyways lol. IP address is nothing special.
Old 03-09-2004, 07:29 PM   #23
KrazyPony's Avatar
I have mine set to auto detect my settings, on the PC for the network, not specified...
might be your problem, doesnt seem to be getting the request sent out of the router and back to the ISP in enough time, and then the ending result your PC cant talk to the network...
just a hunch!
10:33 PM
