Car cuts out in the morning. - Mustang Evolution
Old 02-17-2004, 12:13 AM   #1
Send a message via AIM to Black00GT
I have a 2000 gt and in the morning i will start it up, and it will run for about 5 seconds and then it stutters like it's not getting fuel. then it will go back to the normal idle. THen i will back up and drive about 75 yard to the main road and stop at the stop sign. When i try to take off it doesn't go any where it just barely keeps just so i give it gas and wait until the rpms start to cum up to about 2k and then it's fine. never stutters again for the rest of the day. btw it's usualy about 30F int he mornings. what the hell is wrong?
Black00GT is offline   Reply With Quote
Old 02-17-2004, 08:39 AM   #2
Rick0636's Avatar
You don't by chance have a black diablo chip in there do you?
Old 02-17-2004, 08:51 AM   #3
no. the only mods i have is a 1/2 inch plenum spacer and a k&n filter.
2003 Silverado Z71
Mods:
K&N filter, Black diamond plate toolbox, and billet grille on the way.
Future mods:
6" lift kit, rims and tires, Catback, Rhino lining, System
Old 02-17-2004, 10:51 AM   #4
Rick0636's Avatar
I had two defective black diablo chips that wouldnt' start right when they were cold, if you could get the car to start and run it would do fine then, or if it was a warm day then it would run fine. That is why I asked. Once I figured it out and removed the chip it did fine and ran normally.
Old 02-17-2004, 01:01 PM   #5
Rick0636's Avatar
When you installed that plenum spacer, did you use two new gaskets? If you didn't you could have a gasket leak causing a vacuum leak which could cause a problem, not sure it would do what you said.
Old 02-17-2004, 01:33 PM   #6
well i used one new one. for inbetween the spacer and the plenum. But the lwer intake has that o-ring type gasket. so i don't think it would be that.
2003 Silverado Z71
Mods:
Future mods:
Old 02-17-2004, 09:33 PM   #7
anyone else have an opinion?
2003 Silverado Z71
Mods:
Future mods:
1998 V6 Mustang fuel pump electricity cuts out.. help plz!? 98v6stang101 Pre-2005 V6 Mustang 4 07-07-2008 10:42 PM
What a morning.. wiarumas The Bar 5 04-14-2006 11:52 PM
Tax Cuts for the rich!!!! Brent The Bar 5 09-23-2004 11:47 PM
More Exhaust In The Morning jimmy_beaner The Bar 7 08-28-2004 10:51 AM
11:55 AM
