More Problems - Mustang Evolution
Old 04-29-2004, 07:55 PM   #1
More Problems
alright after finding out the rockers are peaces of crap. I took all the poly locks off and removed the rockers. Put the intake lifter on the the bottom of the loob and put the timming mark on zero. got ready to adjust the new comp rollers. Then to my surprise found out that one pushrods was at an angle. So thinking it just moved out of the center of the lifter put it back and pulled back. It didnt feel right so i looked down the head to see the lifter. Then what do you know. It blew up. however its not a big problem. The c clip on the top of it just broke. So thinking i could snake the lifter back up threw the hole in the head and put it back together i ran into a problem. It would not fit but only barely. i was surprised that it blew up because they are the comp ones. anyway now im waving my magic wond hoping i dont have to pull the intake. i have everything back on the lifer except the c clip. Since the lifter is pumped up i but the pushrod on it and put pressure on it and now waiting to see what its going to do tommaro. then hopfully be able to put the c clip on with two long screw drivers and a lot of luck. Has anyone done this before.
Toxinz is offline   Reply With Quote
Old 04-29-2004, 08:38 PM   #2
Never done it before but good luck.
Old 04-29-2004, 09:19 PM   #3
Ponycarman's Avatar
You got way more patience than I do, I'd of already pulled the intake. I just hope you don't find a wipe lobe too.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 04-29-2004, 09:34 PM   #4
Fishers Stang's Avatar
dang man...
Charles
Old 05-01-2004, 10:09 PM   #5
Sorta forgot to post. Anywho last friday i put the lifter back together. I didn't wipe out my cam. But putting that c clip back on the lifter was quite a challenge. I did it though. Didnt have to pull the intake or anything. So now if any of you run into the same problem you could most likely do the same. By the way the comp cams roller rockers came and they look the same but better quality.
87 problems 87lx50 1979-1995 Mustang GT 9 03-18-2007 05:36 PM
Problems Once Again... MyStangStanks Pre-2005 V6 Mustang 3 11-20-2006 06:25 PM
more problems charkelly9 Mustang Audio & Video 18 05-19-2005 07:22 PM
a/c problems Warfire80 1996-2004 Mustang GT 6 11-29-2004 04:52 PM
Problems: Smokedya95stang ME Site Help & Announcements 0 03-06-2004 06:51 PM
03:53 AM
