GST guy - Mustang Evolution
Old 06-24-2004, 05:31 PM   #1
MusclesFromBrussels's Avatar
Send a message via AIM to MusclesFromBrussels
GST guy
Im getting the Greddy Profec B Electric Boost controller. You have any interest in my Hallman Pro Series MBC?
MusclesFromBrussels is offline   Reply With Quote
Old 06-24-2004, 06:01 PM   #2
Thomas91169's Avatar
hmmm, is it a dual stage?
id like one with a dual stage setup that can be switched from the drivers seat. i think ill be going with the dejon tool mbc-2b that has a lower boost and a higher boost setting that can be switched from the drivers seat, so i can run low in 1st and 2nd, then hit the switch and bam more boost in 3rd.
-Thomas-
Old 06-24-2004, 06:04 PM   #3
what made you want the profec b anyways?
-Thomas-
Old 06-24-2004, 06:13 PM   #4
nah its not a dual stage.
Profec B spec II is a badass electric boost controller for hte price (under 400). Electric boost controllers r just better then MBC no real way around it.
Better Turbo Response
Faster Spool Time
In Pit Change
Cuts Boost Spike DRASTICLY
Works much Better with a aftermarket Wastegate.
Im running 14PSI thru my wastegate then gonna peak it thru the Profec B to 18psi and hold it to around 17 to redline. With MBC on a better wastegate u just get terrible boost spikes and surge's which is no fun for daily driving and bad news if u boost out of ur Powerband.
Old 06-24-2004, 06:17 PM   #5
yeah i like the profec b too, im just not gonna pay 400 for something that does the same as 130. just cause its more complicated to hook up. boost creep can be alleviated with a better exhaust, 02 housing, and wastegate. which is nothing i have to worry about with a t25, so ill be cool with a manual till i get a bigger turbo.
-Thomas-
Old 06-24-2004, 06:21 PM   #6
any EBC does much more and does it much better then a MBC. Boost Spike and partial boost MUST be tuned out by either the lines its run thru and the settings or thru the PCM/ECU itself. It cant be adjust by how the exhaust is setup? Ur thinking of how backpressure affects boost.
Old 06-24-2004, 07:22 PM   #7
Zim
You want to **** me?
Zim's Avatar
:cough: PM's :cough:
sorry man thats what theyre for
I like toys
new guy from MN redcobravert New Member Introductions & Greetings 17 08-17-2009 08:57 AM
New Guy 12Pack New Member Introductions & Greetings 10 09-14-2005 12:21 PM
Hm...maybe this guy has something. lowflyn The Bar 15 09-12-2005 06:00 PM
V6 Mustang vs, Eclipse GST a00mustangjk Pre-2005 V6 Mustang 3 09-07-2005 01:55 AM
srt 4 vs 3rd gen eclipse GST video MusclesFromBrussels The Bar 50 01-18-2004 02:09 PM
12:38 PM
