ugh massive hatred for my dsm right now - Mustang Evolution
Old 09-29-2004, 10:38 PM   #1
Thomas91169's Avatar
dammit the dsm curse has hit finally. teh car=teh dead.
it all started about in june. i parked it in my garage when we left for vegas. when we got back a week later, the battery was dead, no big deal i thought "oh well its old and doesnt hold charge anymore" so i bought a new one. after instlaling the new one i go to drive it down the street and it died when i went to stop. WTF. so i go to start it and battery dead. i jump it while its down the street and drive it home and it dies again. so i take the brand new battery, which was dead and deep charge it. put it in the car and it starts up, but wont idle for ****. it would drop to 200rpm's, then bump itself back to 700, but as soon as you gave it some load by trying to move it and put it in neutral the idle would go back down and sometimes stall. so i hop up on my little dsm website, post the problem and a few say its my IAC(idle air controller) but later that night i go to see what happens and it idles fine and drives fine, so i think nothing of it.
then a month later same thing, we go camping and i get back and battery dead. then upon restard no idle or crap idle. then after a few hours of idling or driving and letting it die it relearns itself. stupid *** thing.
now the problem has become more frequent until now. last thursday when i got in the morning to go to work id wouldnt start, so i put the jumpers on it and nothing, wouldnt even turn over, so F IT i drove the tbird to work. got home and it jumped fine but still no idle after the restart. the ecu resets itself and has a hard time relearning that it has no IAC to control the idle, well thats my theory at least, and usually mine are right. everyones telling me that my timing is off, but if that were true it would be off the whole rpm range and i would have power loss but when i hit it it feels fast as usual.
problem #2 is that bad idle, which wouldnt happen if problem #1 wouldnt happen, and that is the battery dying. if the battery wouldnt die the ecu wouldnt reset itself and we wouldnt be having this rant.
how to fix problem #1? i have looked all through my wiring for a possible short but have come up "short" of finding one. now i had the battery charged last night and took a little reading with my voltmeter, read 13.9 volts. then i locked the car and when i woke up the battery reads .56 volts, so it died in the 8 hours i was sleeping. i have a theory but it sucks if its true. i belive that when i was rear ended the pass side of the car is tweaked a little bit. that little is enough to make the door be out of alignment, and when i lock it the passenger lock fails to lock, so it tries to lock itself all night long, and kills the battery. the fix would be them taking the car apart and realigning the door. thats a far fetched story but right now im running out of ideas. i was hoping i had a short somewhere but i cant find it. if anyone can think of anything im all ears.
p.s. right now i wish i had got a stang and just left it stock performance wise and just took the 3g's i put into the eclipse for random **** and made the stang look sick as fook then later drop a gt supercharged into it.
-Thomas-
Old 09-30-2004, 07:30 AM   #2
There's definitely something draining your battery down...just a matter of finding out what. Something you could do...is cut the car off, and start pulling fuses out and checking them with meter to see which one's are still sending for more power from the battery...about the only way you'll be able to check for sure what's draining you.
Old 09-30-2004, 08:25 AM   #3
fast64's Avatar
i'm with lowflyn on something draining your battery. but atleast you dont have the dreaded dsm crankwalk
GO BRAVES
Old 09-30-2004, 08:26 AM   #4
Ponycarman's Avatar
One other thing to consider and it's testable.
You battery may have an internal break. You have to load test it to find that out. It'll funk things up very similar to what you are seeing.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 09-30-2004, 09:43 AM   #5
Tbird232ci's Avatar
its also possible the alternator isnt actually charging the battery
Old 09-30-2004, 09:55 AM   #6
Zim
You want to **** me?
Zim's Avatar
yeah but why would it die overnight without him even driving it?
You dont have any lights that stay on do you? Trunks closing all the way... things like that?
I like toys
Old 09-30-2004, 09:59 AM   #7
Rick0636's Avatar
Does your passenger door open when it is supposed to be locked? Just a thought.... I would say you are right in that something is definitely draining your battery, why it started that all of a sudden is the kicker...and it seems to have started while you were on that first trip, there was probably nothing wrong with the first battery that a slow charge would not have fixed. I have had silly stuff like the glove box door not shutting all the way and that little light in there pulling my battery down...
Here is one I remember from Automotive school, a dirty battery cable, or connectors can actually cause a short that can drain your battery, we were told to remove the battery from the box, clean the box out good with soap, water and baking soda and water, same with the battery, the soda and water will neutralize any acid that has gotten on there. Its a good idea if you have a metal battery box to paint the box after you clean it this way. Caution, never get any baking soda inside your battery, this will neutralize the acid inside it and kill your battery.
Old 09-30-2004, 10:11 AM   #8
Zim
Zim's Avatar
when this happened the first time... was that before you got rear ended?
I like toys
Old 09-30-2004, 06:40 PM   #9
dsms are horrible cars they suck (i can say this because i used to own one)... i know what kind of POS cars they are....
Old 09-30-2004, 07:25 PM   #10
97Stallion's Avatar
I'm with you on this one!! Ditch the b!tch and get a stang, then you won't be considered the odd ball anymore. But it's still nice to have the "enemy" lurking around!!
Living one day at a time!
Old 09-30-2004, 08:49 PM   #11
omg mike you are a genious. that right there just made me remember the battery was dead when i picked the car up from when it got fixed after the rear ender. i figured it was dead cause the door was open when i went to get in, so the dome light was on all day from when they parked it there earlier that morning. do you think its possible they created a short somewhere when they put the car back together?
whats weird also is there are other times where i left the car and didnt drive it for a few days and it started up fine.
thing that sucks is i lost my warranty papers. while i dont trust mitsu to work on their own car, id rather just not rack up my brain trying to find something thats probably so simple as a shorted wire or a ground that somebody forgot to put on when they put something back on. im gonna call the place i got the car from to see if they can send me out a copy of the warranty papers. but then ill have to put everything stock or else the technician will be like "well its your aftermarket intake, its letting in too much air for the car to handle thus its shutting down" like the ford guys were saying about my K&N filter when it was dying at a stoplights.
-Thomas-
Old 10-02-2004, 01:15 AM   #12
lol update.
so i deep charged my battery last night and put it in earlier today. started it and it idled, so i take off down the street to see if it would die, and it doesnt. it idles fine. fking retarded thing. so i go to the bank and get my hair cut and no problems. so i go out cruising earlier tonight and its fine. race a few ricers and smoke the crap out of them and no problems. go to a few meets and everyone was in awe over my bak seat mod which is now painted the same grey as my interior. i have the subs installed but the amp is still on its way, i just wanted to see some peoples reactions of the work and all in all it was good. one person said i should have it upholstered, either vinyl or tweed. he knows car stereo and noticed a few of the impurities in the surface and said i should do that. so i might.
just a update, the car runs. well see tomorrow if the battery holds charge or if there is a leak.
-Thomas-
My hatred for UPS grows! MarkuzLS1 The Bar 21 09-14-2006 10:45 AM
DSM Gone....... Thomas91169 The Bar 16 09-22-2005 10:32 PM
Football after a massive rainstorm at night rocks. WhiteStang99 The Bar 19 01-15-2005 12:13 PM
major fine, 17's and F&$@*% up DSM Thomas91169 The Bar 28 11-21-2004 12:25 PM
Hatred!!! Danger Dude The Bar 34 10-27-2004 04:11 PM
05:00 AM
