What happened - Mustang Evolution
Old 10-07-2004, 08:51 AM   #1
elijah's Avatar
What happened
Should a v-6 stock automatic 2000 stang be able to beat a 02 f-150?
From a standing stop at a stop light the guy was revving his engine a bit and so from the stop light I hit the gas and pulled away, then hesitated a little and finally floored it (maybe a second after starting) I was about 3/4 car length ahead then around 50mph he started gaining and was 1/2 length ahead by the time we hit 80.
Is this normal?
If it is normal, I'm definately giving a bigger part of my pay check next week to making sure it doesn't happen again.
elijah is offline   Reply With Quote
Old 10-07-2004, 09:01 AM   #2
Danger Dude's Avatar
Is this normal?
depends on what the F-150 has for a motor was it a V6 or a V8 and of course the driver. I can tell you from 60 MPH a SVT Lightning and my V6 punched it on a open Highway and he really did not pull on me at all we stayed about even to 110 and we both slowed down. Brent, n8r and Whitestang99 Nick were driving behind me and saw it happen.
Old 10-07-2004, 09:11 AM   #3
elijah's Avatar
Is your v6 modded farily heavily?
If I had gotten a good start he wouldn't have passed me until around 80 or 85, and my OD was on. Would it have shifted into 4th even with the gas to the floor? I didn't pay much attention to gear shifts but my accelation died at 75mph.
All I know is it made me mad and motivated to make the v6 faster. And re-affirmed my goal to buy a top of the line mustang (whatever it may be) a few years down the road when my wife and I finish our masters degrees
Old 10-07-2004, 09:16 AM   #4
Yes it is fairly modded. Here is a list I use to have in my sig but it was to much and took it down
RGR Stage 3 Intakes, RPM Heads and 216/225 Cam, 60mm GT T/B, 19# injectors, Flex intake spacer, PCV delete kit, EGR delete Kit, Custom 4R70W w/ shiftkit, SCT tuned, Trans cooler, MAC UDP, MAC CAI, MAC O/R H Pipe with dual Dynomax Ultraflows, 3.73 w/ Trac lok, UPR Shark C&C plates, Bullitt struts & shocks, C springs, Front and rear Cobra sway bar, Steeda STB, Steeda SFC's, FMS Aluminum Drive shaft, Bullitt gauge bezel, ultra clear headlights clear corners, 98 Cobra Rims w/ Michelin 245 45ZR 17 tires, EVal 3.8 emblems. Soon to install RPM BV headsand Harland 1.73 adj RR's
Old 10-07-2004, 09:35 AM   #5
elijah's Avatar
Ahh ok that makes me feel a little better about loosing. It was dark so I'm not sure if it was a lightning or not but it looked like quite a bit of appearance mods had been done and sounded like exhaust but no idea if it was only external mods to it.
But I just found out I have some extra money coming it soon so I'll be ordering a CAI and possibly UDP this week, and going to go scouting the junk yard for exhausts. If I can't find them there I will probably do 3.73s and t-lok then look into exhausts later.
Thanks for the help man. I'm still really new to stangs and racing. I've been driving 4cyl rangers the last 8 years from high school through the end of college and just bought a mustang this monday.
Old 10-07-2004, 09:36 AM   #6
Cool and welcome to Mustang Evolution
Old 10-07-2004, 10:22 AM   #7
I liek gramer
WhiteStang99's Avatar
yeah, i saw the Lightning vs. Corey race.
they did stay even, I was surprised. I expected the lightning to pull much harder. Guess I was wrong. Didn't he compliment you on your "GT" too Corey?
Old 10-07-2004, 10:54 AM   #8
Yes he did
Old 10-07-2004, 11:40 AM   #9
Hey elijah, was the truck an extended cab or standard cab. And regular truck bed or styleside? Easy way to tell what it was
Old 10-07-2004, 12:35 PM   #10
elijah's Avatar
Regular cab flare sides, and sounded great.
Old 10-07-2004, 12:36 PM   #11
Ah ok, prolly a lightning. Any idea whether it had side exhaust and 5 spokes?
Old 10-07-2004, 12:38 PM   #12
chips's Avatar
Send a message via AIM to chips
so it probably had the 4.2 v6. yes, a stock 4.2 can beat a stock 3.8 depending on both driver's abilities.
the only reason Dr. Dre produced "The Chronic" because the bible tells you to smoke lots of pot, and Oedipus used to blaze with the makers of Aqua Fresh tooth paste.
chips is offline   Reply With Quote
Old 10-07-2004, 12:40 PM   #13
chips's Avatar
nope, he said the truck was flareside - l's have stepside.
Old 10-07-2004, 12:41 PM   #14
I know a lot of people with 5.4's in there F-150's
Old 10-07-2004, 12:42 PM   #15
chips's Avatar
Originally Posted by Danger Dude
I know a lot of peopel with 5.4's in there F-150's
not a single cab. short bed single cabs have the 4.2
i believe some work versions with the long bed have the 4.6
Old 10-07-2004, 12:42 PM   #16
Yeh, my roommate had a 5.4 in his 98 4x4...it's stout, surprises me often
Old 10-07-2004, 12:43 PM   #17
chips's Avatar
was it a crew cab?
Old 10-07-2004, 12:50 PM   #18
And...Lightning's have flaresides don't they?? I'm sitting here looking at pics, look like a flareside to me
Old 10-07-2004, 12:50 PM   #19
Nope, ex cab. And he still has it..didn't mean to sound past tense.
Old 10-07-2004, 01:41 PM   #20
elijah's Avatar
Not sure about step or flare sides, but it wasn't a straight bed, the streeet light was on the opposite side of the the truck and the shadow fell right on my car, he sits a little higher than me
Old 10-07-2004, 01:44 PM   #21
chips's Avatar
no, i checked pictures to make sure - they have step side.
Old 10-07-2004, 01:44 PM   #22
Some of the early ones were not any different looking except for the SVT emblem. These were the oncs in the late 90's before the body change though.
Old 10-07-2004, 01:45 PM   #23
chips's Avatar
so, the sides weren't straight? did it look anything like the picture i posted?
Old 10-07-2004, 01:52 PM   #24
elijah's Avatar
Like I said all I could tell was that the top of the bed had a curve to it, and then the light went greeen. Sorry I couldn't get out the calipers and measure it for ya
I glanced over and caught the curve of the bed then we took off.
What happened to... Stumpy ME Site Help & Announcements 8 05-03-2007 01:00 PM
Whatever happened to 69boss429 The Bar 12 02-23-2007 04:58 PM
It happened... Zim The Bar 34 02-12-2007 04:30 PM
Whatever happened too..... Brent The Bar 16 12-12-2005 09:13 PM
What happened on 4/20 Kiljosh The Bar 10 04-26-2005 11:24 AM
03:07 PM
