Digital Speedometer and other tricks - Mustang Evolution
Old 10-19-2004, 10:32 AM   #1
I liek gramer
WhiteStang99's Avatar
I don't know if anybody remembers Jimmy Beaners thread about the "hidden" features in a 99+ dash, but I finally thought I'd try them out on the way back home from Decatur. It's pretty sweet to have a digital speedo.
Anyways, the reason I made this post was I noticed discrepancies between my gauges and the digital read out. For example, the gauges read 70, and i got 68.2-69mph on the digital. Gauges read 100, digital readout said 98.2-99mph. Anybody know why?
edit: here's the thread. digital MPH???
Old 10-19-2004, 10:34 AM   #2
Zim
You want to **** me?
Zim's Avatar
cause your wheels probably offset the speedo a little bit from your stock ones... plus the analog guages are horribly innaccurate in our cars.
I like toys
Old 10-19-2004, 10:35 AM   #3
I liek gramer
I thought about that too, but I haven't corrected anything for my tire sizes, so why would they read differently?
Old 10-19-2004, 10:37 AM   #4
Zim
Zim's Avatar
cause your tires probably have a circumference thats just a few centimeters larger than your stock tires so the speedo will read a little faster than what youre actually going.
I like toys
Old 10-19-2004, 10:41 AM   #5
Monkey's Avatar
because both speedos run out of the output shaft of the transmission. The digital one is going to be more accurate because it can calculate exactly how many rpms the driveshaft is spinning and plug that thru the gear ratio you have. The analog needle does the same thing, but it is less precise. Look at the needle when it is pointing at 70mph or any round number. See where it could be .5mph off either way? The physics of looking at an analog needle and reading the corresponding number incorrectly is called parallax. That is because you cannot get 100% precise w/ a needle. The speed you are going varies (in your mind) from the position of your eyes on the needle. That's why when you're in the passenger seat and you see someone driving, it looks slower then they are actually going. With your head above the needle, if you are off center at all, you will read it at least .5-1.0mph off.
Just some fun biology on how the eyes percieve things. Anyway, the needles are also kinda inaccurate too on the mustangs. Remember, if you push a stock v6 to the limiter, the needle will say around 110-120 when the govorner kicks in at 116mph. That shows the inaccuracy of it.
Old 10-19-2004, 10:47 AM   #6
Zim
Zim's Avatar
well way to get scientific on him and make me look like a friggin ****** monkey
I like toys
Old 10-19-2004, 03:44 PM   #7
Seph's Avatar
My needle stopped at 116, didn't even want to go beyond that. Slightly disappointed But yeah
-Patrick
http://home.socal.rr.com/sephiros/images/NewBan.jpg
Seph is offline   Reply With Quote
Old 10-19-2004, 08:59 PM   #8
I liek gramer
yeah, i kinda figured that lookin at it from different angles made a bit of difference there monkey. btw, im a biology major.
It's just the difference wasn't the same as what could be caused by that. I'll just accept that the gauge readout is innaccurate.
Old 10-19-2004, 09:32 PM   #9
Monkey's Avatar
I don't know what everyone knows and doesnt know. I have a biology degree and figured i would try to sound smart
Old 10-19-2004, 10:58 PM   #10
Actually, what it's from is that the speedometer is set 2-3 mph slower than you are actually going so you can't blame Ford for a speeding ticket saying it is calibrated wrong. That is why the digital will read 2-3 higher than the analog.
Old 10-20-2004, 02:17 PM   #11
fast64's Avatar
i am about to go try this in my dads car.
GO BRAVES
Old 10-20-2004, 02:24 PM   #12
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
I'd call parallax a physics phenomenon though. Optics fall under the umbrella of physics
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 10-20-2004, 03:17 PM   #13
fast64's Avatar
just did it on my dads car, this is a pretty neat trick
GO BRAVES
Old 10-20-2004, 04:07 PM   #14
I liek gramer
I was thinking that too, but oh well.
Old 10-20-2004, 04:30 PM   #15
MonteCitan's Avatar
actually it's built to err on the side of caution (IE reading high) manufactured that way, so it doesn't read slower than you're going..
Old 10-20-2004, 05:33 PM   #16
Exactly, it reads about 2-3 mph higher than you are actually going.
Old 10-20-2004, 07:29 PM   #17
I liek gramer
^ that's what I was thinking, if it was built to err to one side or the other.
help with speedometer roach 1996-2004 Mustang GT 2 06-20-2009 07:29 PM
myth busters bust MPG tricks. eagle05 The Bar 7 01-13-2007 09:14 PM
v6 speedometer help. 01stang232 Pre-2005 V6 Mustang 5 01-13-2007 08:20 AM
Awesome Pool Table Tricks 04MonteSS The Bar 7 05-24-2005 07:21 PM
10:09 PM
