would this work? - Mustang Evolution
Old 10-25-2004, 09:18 PM   #1
Fishers Stang's Avatar
would this work?
I know its prob not in the right topic area but o well. work a CD player out of a 99 Explorer fit into my 02 crown Vic? they are both the large CD players (ford big ones) but would the wires work? if you need pics ill try to get some
Charles
Old 10-26-2004, 01:00 AM   #2
Seph's Avatar
dunno
-Patrick
http://home.socal.rr.com/sephiros/images/NewBan.jpg
Seph is offline   Reply With Quote
Old 10-26-2004, 02:46 AM   #3
Thomas91169's Avatar
the harnesses might not be the same, but you could prolly figure out which one is battery, ground, 12v constant, and then speakers youll have to fiddle with and figure out which ones are rear, front, left and right, might take a while. maybe a chiltons or haynes from both cars would make life easier.
-Thomas-
Old 10-26-2004, 07:45 AM   #4
Do they both go in the slot the same? I believe the exploders have the holes on the sides you stick the ford tools into to remove the radio. That's the first thing I'd worry about. Otherwise...just experiment with wires is all i can say...what I did on my car was look at an aftermarket harness adapter made for the stang and traced wires through the harness to the original wires and labeled them all.
Old 10-26-2004, 08:11 AM   #5
the players mach up, just didnt want to go cutting wire if i dont have to.
Charles
Old 10-26-2004, 11:31 AM   #6
Well plug er in and see if it works lol. If it doesn't..then you have to cut wires
Old 10-26-2004, 11:41 AM   #7
chips's Avatar
Send a message via AIM to chips
it's not a big deal. if you were in S.A., i could wire it up for you.
the easiest way to do it is to go to best buy. buy a harness for your car, cut the wires and splice them onto the harness wires. then the radio will just plug in.
this can also be done without a harness. you just splice all the wires together. it's easy, but if the colors are different, it can take a little while to do. i reccomend the harness. it only costs ~$15
the only reason Dr. Dre produced "The Chronic" because the bible tells you to smoke lots of pot, and Oedipus used to blaze with the makers of Aqua Fresh tooth paste.
chips is offline   Reply With Quote
Old 10-26-2004, 12:38 PM   #8
I seriously doubt that ford changed wiring harnesses in cars.
It should work
Old 10-26-2004, 01:08 PM   #9
01GTType's Avatar
Send a message via AIM to 01GTType
Hey don't forget if you don't want to cut wires to get a wire adapter for the explorer it will clip right on and then all you have to do it figure out the mustang wires and no wires to cut.
01GTType is offline   Reply With Quote
Old 10-26-2004, 06:25 PM   #10
hah thanks Brent, we are going to check it on friday. BTW I was talkin about my Vic, not my stang. also cause my vic is a PI, the front 2 speakers are set up for a 800mhz (or anyother band) radio. I only use the rear speakers thus the reason i dont want to cut any wires. thanks for the help/
Charles
Getting some work done Scut95 The Bar 5 06-15-2009 09:11 PM
Some of my Work. Dwisforme05 Pictures and Videos 16 02-10-2009 09:39 AM
So where does everyone work? Dom The Bar 52 11-30-2006 05:50 AM
I work to much rocknbronco The Bar 4 09-12-2006 11:47 AM
It doesn't work!!! CaptHowdy5150 ME Site Help & Announcements 3 04-07-2004 01:39 PM
12:12 AM
