Welcome to Mustang Evolution.
10-16-2003, 11:34 AM
#1
Swapping brakes
FormerMod
City: Riverside County, CA
Theres a fox body salavge yard in chester which is 20 minutes from my house.
He has tons of parts.
He has a ton of 8.8 rear ends with all kinds of different gear ratios for like 200 bucks!
My question is, Their 4 lug. I know id have to switch over the brakes, but is that easy? hard?
Anyone do this? Is there a how-to anywhere so i can read up on it?
Thinking i might do this.
Are you a Mustang fan? If so we invite you to join MustangEvolution.com. Once you join you'll be able to post messages in our forums and upload pictures of your Mustang. You will also be able to browse our site with limited advertisements as a thank you for joining our community. What are you waiting for? Join up now and tell us a bit about your Mustang!
10-16-2003, 11:43 AM
#2
God
City: DFW, TX
you have to swtich brakes and axles.
swapping brakes is just taking the caliper off, the rotor, and the dust shield if desired. then you just re-attach them to the new axle and plop that bad boy in the carrier. you could prolly even do it w/o having to disconnect the brake lines so you wouldnt have to bleed the brakes.
10-16-2003, 12:24 PM
#3
Taking life one day at a time
City: Simpsonville
State: South Carolina
Hey Monkey I am not absolutely sure but think the Fox body rear end setup is narrower wheel to wheel. You might need to use different axles
10-16-2003, 01:18 PM
#4
postarama
City: Southaven
State: Mississippi
You'll also have to buy two types of wheels if you ever buy new ones. That could get annoying. There may be more involved in this than you think
90 7up vert - new project
-92 bronco 5.slow and 33's
10-16-2003, 02:10 PM
#5
FormerMod
why would i need 2 types of wheels?
10-16-2003, 02:12 PM
#6
Top Breeders Recommend Blue Donkey.
City: Dover
State: New Hampshire
I think the assumption you're keeping the fox 4-lug axles....
Numai doua lucruri sunt infinite: Universul si prostia omeneasca.
De primul nu sunt sigur.
-A Einstein
10-16-2003, 02:59 PM
#7
FormerMod
no, thats why iam going to swap brakes and what not. lol
10-16-2003, 04:30 PM
#8
God
City: DFW, TX
ok, i had a fox body rear in my car. its the same exact width from 84 (first year they made 8.8s) up to 98s. so it will bolt up just fine and look just the same you have now. you can get a 99+ which is 1.5" wider if you want the rear gaps filled out some. looks halfway decent, but theyre gonna be more expensive.
so no, you dont need different axles. his stock ones will be fine (granted theyre in good shape and the heat shield on them is still good). his stock brakes are the same ones they have been using for SN95s in GTs and 6'ers. it will just bolt right up.
no need for second set of wheels. your stock one will be fine as long as you re-use your stock axles.
10-16-2003, 04:35 PM
#9
City: Simpsonville
OK I dont know much about the fox body swap. I just remember reading something in passing about all the different rear ends
Thanks for the info Brandon
10-16-2003, 04:41 PM
#10
God
City: DFW, TX
:thumb2: thats what im here for
10-16-2003, 04:45 PM
#11
City: Simpsonville
See even at 43 years I can learn from the smart young ( Admittedly the wrong school) college guys !!!!!! 8) 8)
10-16-2003, 08:06 PM
#12
postarama
City: Southaven
State: Mississippi
Ha sorry about that earlier post. I'm out of it today. Been wrong about everything I've tried to do. Oh well. Thanks for correcting me though. I'll always take positive corrections and comments. My mind just isn't with me today.
