Tire sizes for bullet rims??? - Mustang Evolution
Old 04-10-2019, 07:14 PM   #1
69ponyxprs's Avatar
My son has a set of ARE Bullet rims 17” in
front standard (17x8 maybe?) and 18”x9” in rear. They are a special edition Captain America rim set. We figure to use 245/45R17 on the front. What’s the widest he can place on the rears? He has a 2000 GT and wants as wide a tire as he can out on it.
69ponyxprs is offline   Reply With Quote
Old 04-11-2019, 12:41 AM   #2
275/35/18 will be a good rear size for that rim but some brands run wider or narrower than others. For instance, BFGs generally run wide so a 275 might actually be TOO big for a 9" wide rim with them. Nittos run narrow, on the other hand, so you might need a 295 Nitto but it'll be the same actual width as the BFG. You can check actual section widths on tirerack usually.
Just remember wider is not always better, you have too wide a tire on a rim and it's going to actually DECREASE performance.
For the fronts, 17x8 is the OEM rim size so OEM 245/45/17s will get you to the 25.7" stock height.
You can also go with a taller tire out back like 275/40/18 for 26.6" if you wanted to fill up the wheel well a little more or decrease highway RPM slightly. You will need to recalibrate the speedometer or it'll be off 5mph or so.
Old 04-30-2019, 12:18 AM   #3
Revvv's Avatar
275 wide is normally what is used on a 9" wide wheel. You can easily go up a tire size or two though. This depends on the tire.
Sent from my SM-G975U using Tapatalk
« New Michelin Tires | - »
17 inch bullet rims what size tire to use ? Simon2308 Mustang 101 - Tech Basics | Ask an Expert 6 08-23-2017 12:34 PM
Tire opinions & tire sizes GT5h0e Mustang Wheels & Tires 6 10-01-2014 05:41 AM
Compare tire sizes, even for different size rims. Otlaw80 Mustang Wheels & Tires 4 06-15-2009 10:03 AM
Tire Sizes for 18's Black95GT Mustang Wheels & Tires 16 04-04-2004 08:33 PM
Tire Sizes Laser02 Mustang Wheels & Tires 26 01-10-2004 12:22 AM
» Premium Vendor
03:58 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
