Code P0442 V6 - Mustang Evolution
Old 05-13-2018, 11:05 AM   #1
Redesiuk's Avatar
Code P0442 V6
Alright, I ended up getting the check service light coming on just before inspection (of course right?), and as far as I can tell so far, I don't think it's the gas cap, as I replaced it, and drove it a bit, so I'm not sure what else it may be.
Is there anyone here, who for a definite had a certain issue I should tackle first, I was going to go cheapest to most expensive, since sometimes the dumbest thing would cause the small emission leak. I looked that up it said something with the charcoal canister hoses. I'm not sure if it truly is that. It's a 2003 v6. Any suggestions?
" For with much wisdom comes much sorrow ; the more knowledge the more grief. "
Redesiuk is offline   Reply With Quote
Old 05-13-2018, 05:49 PM   #2
jkeaton's Avatar
Could be any one of these things. Start with the simplest/cheapest.
A loose or improperly affixed gas cap
A non-conforming gas cap (i.e. not factory/original brand)
A small leak/hole in a fuel vapor hose/tube
Other small leak in EVAP system
Faulty vent o-ring seal
Defective vent valve
Defective purge valve
Defective leak detection pump
03 GT Convertible
07 V6 Coupe
17 Charger SRT
jkeaton is offline   Reply With Quote
Old 05-13-2018, 09:15 PM   #3
Redesiuk's Avatar
Yeah, I replaced the gas cap already with an actual locking one I bought since the old one looked gunked up. Figured I'd just buy a new one. Some say replace the grommet as that could do it too. Didn't turn it off even after I drove it for a bit though with the new cap, so I'll have to move onto the next thing. My other car, the focus, when it wasn't on all the way would turn the gas cap light on then eventually check engine. But, different cars all together.
Old 05-14-2018, 05:58 AM   #4
jkeaton's Avatar
Is the new gas cap an actual OEM (dealer bought) cap? It may sound weird, but sometimes only an OEM cap will work.
03 GT Convertible
07 V6 Coupe
17 Charger SRT
Old 06-09-2018, 12:39 AM   #5
Venum615Fighter's Avatar
I'm having the same issue. I realized I'm leaking air on the passenger side egr tube where it meets the header. If I were you I'd get your car smoke tested.
I don't have emissions where I live so I'm deleting the whole egr system.
Venum615Fighter is offline   Reply With Quote
Old 06-17-2018, 11:21 AM   #6
Redesiuk's Avatar
Yeah, I suppose I'll have to do that, or maybe just replace that part since you mentioned it. Problem is my first manual, so getting it to a shop is annoying, I don't have much time between work to try it out, so I also can't full get it there.
Old 06-17-2018, 07:46 PM   #7
I deleted the egr system and the car runs like when I first bought it if not better. There's no hesitation, studder, or struggle on load. The rpm's are steady.
Here's the write up I used to delete the system:
http://www.moddedmustangs.com/forums.../topics/219948
I didn't do everything word for word but so far so good.
Old 06-19-2018, 10:38 AM   #8
Sometimes, it is not the miles driven with a code fix in place, but the number of on/off cycles (typically five or more) for the engine......have you tried turning the code off to see if it comes back on?
Autozone has code readers, and will plug into your car for no fee, and I think they can turn off the code as well.....
Old 06-19-2018, 11:46 AM   #9
Man, P0442 is a PITA code.
I had already replaced the charcoal canister and purge valve, yet the code kept coming back. I smoke tested it and couldn't find the issue. Honestly, the smoke testing was harder than I thought.
Long story short, CHECK YOUR HOSES man. I had to go back to my mechanic and they swapped out the charcoal canister again, but the CEL came back in 2 days.
You know what it ended up being, or at least was also part of the problem?
Old hoses. Looked ok, but they were dry and cracking from the inside out. $2 fix from bulk vacuum hose.
Conspiracy is offline   Reply With Quote
Old 07-20-2018, 11:33 AM   #10
Redesiuk's Avatar
I have actually cleared it, so far it hasn't come on, but I didn't drive that far, so maybe it was just the gas cap, I'm uncertain, but I plan on replacing hoses, and moldings, etc because it's all gonna dry rot eventually. I'm waiting to see then go down the list from smaller to bigger, like the hoses to replace.
Codes P1233 and P0442 after fuel filter change John_04_Zonker Pre-2005 V6 Mustang 3 10-14-2015 08:34 PM
Error code P0442 Kstangs2002 2011-2014 Mustang GT 4 03-22-2015 06:38 PM
CEL p0442 bsyo1021 2011-2014 Mustang GT 3 06-21-2014 12:42 AM
CEL and code P0442 TwoSeveN 2005-2010 V6 Mustang 6 08-16-2011 08:15 PM
P0442 and P0456PD CEL OsirisGuy 1996-2004 Mustang GT 4 09-01-2009 11:57 AM
» Premium Vendor
08:46 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
