Hvac - Mustang Evolution
Go Back   Mustang Evolution > 1979-Current Mustang GT || Tech and Talk > 1979-1995 Mustang GT
Old 06-12-2018, 07:01 PM   #1
havhammer's Avatar
Hvac
Has anyone had this problem and solved it, if so what was the issue?
So when my heat or ac is off in the car it always has warm "air" coming out of the floor vents. I've had this problem with my last couple foxbodys. When i had the dash out to do the heater core, i vacuum checked all the vacuum "solenoids" behind the dash to see if they hold vacuum. They did, what else could be the issue? The temp control knob works, it changes from hot to cold. Any ideas? Thank in advance.
Sent from my SM-G965U using Mustang Evolution mobile app
havhammer is offline   Reply With Quote
Old 06-13-2018, 12:03 AM   #2
It's possible that the foam that is used to seal the blend doors as they change position has deteriorated over the last 24+ years, and there is hot air leaking from the heater core compartment of the HVAC box even when the temperature control is in the full cold position.
When you replaced the heater core, did you confirm that the blend door was indeed closing completely, and making a good seal?
Old 06-13-2018, 04:53 AM   #3
havhammer's Avatar
Good idea! I dont remember. Lol i think i may have checked the door to see if it was moving but may not have checked the seal. Thanks
Old 06-13-2018, 05:33 AM   #4
There is always some amount of "fresh air" flowing through the car even with the HVAC system off. Generally the fresh air is admitted through the cowl area and it will be warm if the outside temps are warm. Having the HVAC "off" does not mean that outside air is completely cut off from entering the vehicle....you would die from oxygen starvation in very short order if it did...
jkeaton is offline   Reply With Quote
Old 06-13-2018, 06:44 AM   #5
havhammer's Avatar
Thanks i understand there should be some airflow but this is "a stiff breeze" on my ankles and it doesnt seem to be ambient temperature.
HVAC Controls move tjvaughn Pre-2005 V6 Mustang 0 07-09-2011 09:35 PM
I've managed to lose the thread -Changing hvac and speedometer color... Black_Sunshine Pre-2005 V6 Mustang 0 07-15-2010 10:05 PM
HVAC Fan Settings OsirisGuy 1996-2004 Mustang GT 18 12-15-2009 09:07 PM
HVAC fan control issue jimmy_beaner 1996-2004 Mustang GT 1 01-24-2009 11:20 AM
Replacing lights in the HVAC controls.. MonteCitan Pre-2005 V6 Mustang 3 09-27-2004 09:08 PM
» Premium Vendor
09:18 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
