Turn, hazards, break lights - Mustang Evolution
Go Back   Mustang Evolution > 1979-Current Mustang GT || Tech and Talk > 1979-1995 Mustang GT
Old 08-18-2018, 10:30 PM   #1
Hey all. I was rewiring the headlight switch on my 88 this morning. Got it all wired up again and now the turn signals, break lights, and hazards do not work. However, when I move the multifunction switch to activate the turn signal, I can hear the sound of a turn signal clicking as if they were working, but no lights appear on dash or on the exterior. Any help would be greatly appreciated. Also grounded out a ground while working on the headlight switch which melted a ground wire all the way back behind the dash. Thank you in advance for any help or opinions as to what could be wrong..
Mike1988 is offline   Reply With Quote
Old 08-19-2018, 04:09 AM   #2
Grabber Blue5.0's Avatar
"brake" not "break"
Old 08-19-2018, 01:43 PM   #3
Grabber is being a big help today....
You need to go back through, and carefully re-inspect your work. Make sure that the wires all got reattached to like colored wires etc. Also,check all of the related fuses, and the connector for the headlight switch, to make sure that it is undamaged.
Old 08-21-2018, 03:35 PM   #4
You clearly did not ground a ground, or nothing would have happened. You short-circuited something with power. That ain't good, as you saw. It can do damage to any electrical component it was attached to.
Where to start....it could be a bunch of things but the best advice is what you've already received, go back and check your work. Something isn't connected to the thing it's supposed to be. Until you're sure this is right, don't connect power again. Check your circuits with a continuity checker before applying juice. A cheap voltmeter can be very helpful here
Old 08-21-2018, 08:09 PM   #5
I actually did away with the headlight switch and put them on a toggle switch. The two grounds I just twisted together. The hazards end up blowing a fuse when putting them on, but the brake lights are working once I changed out a bad fuse.
Old 08-21-2018, 10:31 PM   #6
Oh.
In that case, I recommend purchasing an OEM style headlight switch and connector from the auto parts store and wire everything to the factory wiring harness correctly.
Turn Signals, Brake Lights, and Hazards are not working. Rusty_Surf90 1996-2004 Mustang GT 6 04-26-2015 03:39 PM
How to Mute Kenwood Nav Voice Prompts / Turn-by-turn Guidance EastTNMustang Mustang Audio & Video 0 11-03-2013 04:25 PM
Why Three Break Lights? Milehigh STK Pre-2005 V6 Mustang 9 07-11-2013 07:55 AM
Turn lights/ brake lights Mustang_Madness 1996-2004 Mustang GT 8 01-14-2013 08:14 AM
No hazards lights - ideas? 6805stang Classic Mustangs 12 09-30-2012 07:19 PM
» Premium Vendor
09:16 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
