Boosted Car popping and stumbling when accelerating - Mustang Evolution
Go Back   Mustang Evolution > 1979-Current Mustang GT || Tech and Talk > 1979-1995 Mustang GT
Old 09-16-2018, 12:52 PM   #1
Haav2's Avatar
As of late my 89 fox supercharged hesitates and pops when i accelerate HARD, somewhere around 3500rpm and up. doesn't do it in low rpm accelerations.
I'm at 6lbs of boost and fuel pressure at 50psi. when i accelerate hard, my air fuel ratio goes super lean around 23.00!! 14.7 at idle.
I currently have a 340lph fuel pump PLUS a T-REX secondary external pump running.
do i need more fuel pressure? or is there something wrong with my fuel system?
Haav2 is offline   Reply With Quote
Old 09-16-2018, 04:34 PM   #2
Did it NOT do this when you first installed everything? I’d guess that (although 23 to 1 is waaaay too lean!) you may need more robust injectors to support higher boost levels.
Old 09-16-2018, 04:55 PM   #3
Rapinator126's Avatar
Lol melt them pistons yea yea
Sent from my SAMSUNG-SM-J727A using Mustang Evolution mobile app
Old 09-17-2018, 08:32 AM   #4
Definitely sounds like a fuel delivery problem.
The first two things to check are the fuel filter, and the fuel pressure regulator.
Old 09-17-2018, 04:37 PM   #5
Wow !!!! 23 to 1, How long has this been going on ? Lucky to still be running. Do you have a FP gauge that you can moniter while this is happening to make sure pressure isnt dropping?
WAR HORSE is offline   Reply With Quote
Old 09-17-2018, 11:34 PM   #6
Haav2's Avatar
It ran fine, lots of power! just until a month and a half ago this started happening. I only drive the car on the weekends and less now because of this problem.
Old 09-17-2018, 11:40 PM   #7
Haav2's Avatar
I installed one last week but its in the engine bay. it read 60psi when first installed it.
keep in mind the problem was still there with 60psi, i just installed it to see where i was at in fuel pressure. so i dropped it to 50 psi and the problems still there. i pulled the vacuum line that goes to the fuel pressure regulator at idle and psi goes up a bit, i guess the fpr is working i guess...
I did notice my fuel pressure goes all the way down quickly and holds no psi when i shut the car off, perhaps theres a pressure leak somewhere?
Old 09-17-2018, 11:42 PM   #8
Haav2's Avatar
thats what i was suspecting even though i replaced my fuel filter i guess its worth a check. I've been hearing about a fuel pump or fuel pressure check valve online and maybe it could be bad, i just gotta find the dang thing.
Old 09-18-2018, 12:12 PM   #9
There are three places that it could be leaking internally.
On the stock pump, there is a check valve inside of the in-tank fuel pump. Not sure about your aftermarket pump.
The fuel pressure regulator can develop a leak.
A fuel injector can be stuck open.
Can probably rule out the stuck fuel injector, in your case.
You really need to figure out a way to monitor the fuel pressure while driving, and see what it is doing while re-creating the conditions when the pinging occurs. The fuel pressure might be good at idle, but there may be a problem with the fuel volume when the engine is under full load.
Old 09-18-2018, 12:17 PM   #10
I just had to replace pumps on my 04 Cobra , ran fine until you got on it like to pass some body , acted like it was running out of gas, changed pumps problem went away , car ran great before this ,
Old 09-19-2018, 03:27 PM   #11
You do have the car tuned properly right? You didn't just set the fuel pressure and roll did you?
car is stumbling TurboCobra Mustang Wheels & Tires 1 07-23-2014 10:23 PM
Stumbling carlosmorris29 1979-1995 Mustang GT 1 06-05-2014 05:58 PM
Car Stumbling/Hesitating v8pony 1996-2004 Mustang GT 8 03-11-2014 04:35 PM
2nd gear popping popping out Cleancobra22 General Mustang Discussion 4 05-29-2012 08:36 PM
Stumbling and surging dancoy2000 1996-2004 Mustang GT 3 02-25-2008 10:47 AM
» Premium Vendor
09:14 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
