First Mustang - Mustang Evolution
Old 01-23-2019, 05:06 PM   #1
nobringer's Avatar
First Mustang
Just picked up 2002 Mustang GT 56k original miles. Kooks long headers catted x pipe and SLP loudmouth exhaust, sr lowering springs, BBK 78mm throttle body 3.73 ford performance gears. This was all already on the car at purchase now looking to see what I want to do next was looking at bilstein for suspension, steeda underdrive pullies, maybe an upgraded MAF sensor, new rear lower control arms aluminum driveshaft if I can find one for an
Automatic they seem to be out of stock everywhere. Would love to hear more suggestions for some extra power. Oh and have been thinking about B&M ratchet shifter (anyone have any expierence with ratchet shifter?)
nobringer is offline   Reply With Quote
Old 01-23-2019, 05:12 PM   #2
nobringer's Avatar
Couple pictures of the car
ID:	257945   Click image for larger version
Old 01-24-2019, 05:50 AM   #3
jkeaton's Avatar
Welcome to MEVO. Here is a good place to start.
https://www.mustangevolution.com/forum/f392/t364227/
03 GT Convertible
07 V6 Coupe
17 Charger SRT
jkeaton is offline   Reply With Quote
Old 01-24-2019, 07:07 AM   #4
Nice car and nice mileage.
UD Pullies will do nothing, don't waste your money
Putting another MAF in there will do nothing, don't waste your money
Aluminum DS will do nothing except lose a few lbs, don't waste your money
The BBK setup isn't doing anything for performance but if its already on there and isn't causing issues then dont' worry about it. BBK is very hit or miss with their throttle bodies as far as quality and operation.
Definitely work on suspension.
-Steeda or MM lower control arms
-New axle side upper control arm bushings and new STOCK upper control arms, you need the stock ones in there to allow the suspension to flex, otherwise it'll bind up and you can get snap oversteer.
-Blistein makes good shocks and struts for sure, Konis are good too. I'd replace the SR springs with Steeda Sport or HR Red springs, new isolators and if you don't have CC plates yet get Steeda or MM 4 bolt ones.
-Subframe connectors are required, Steeda, MM, Global West are all good.
Now, at this age the rubber in the front is likely all shot to hell too so new A arms, new balljoints and new tie rod ends/swaybar endlinks are a good ide as well. Stock replacement A arms with OEM style balljoints are cheap on Amazon at $80 per side and work well. You can also go with the BMR A arms if you want to go all out although for a street car that's probably overkill.
Obvioulsy a good set of wheels and tires too.
Besides that just basic routine maintenance. Do the plugs, rebuild the OEM COPs with a $35 rebuild kit, all fluids and check around the plastic area of the intake manifold where the metal crossover bolts to the plastic to make sure its not leaking since those areas warp over time.
Ratchet shifter... I wouldn't, with a good tune and a j mod the computer will shift faster than you will. Really only a good idea for a manual valve body car.
More power? There is hardly any bolt on power to be had for these cars and you already have it with longtubes and full exhaust. CAI/Pullies/MAF/TB... all of that does nothing. Full exhaust and tune and you get 250-260 at the wheels. Next step is cams which I would do the MHS Stage 2 NA cams and that'll get you up to 280rwhp or so. After that its power adder or a full build.
Oh, tune. Get a good tune. And by good tune that means not bama. A good remote or dyno tune is what you want, not a "tunes for life" package that is just generic canned tunes.
Old 01-24-2019, 09:40 AM   #5
nobringer's Avatar
Thanks for all the advice really appreciate it ! And yes I’m looking to get an actual tune done the last owner just did Bama tunes I believe and I have started looking into cams already just need to find a good shop around me I’m in Pittsburgh PA.
Old 01-24-2019, 11:12 AM   #6
Lorraine's driver
ab_mach1's Avatar
She looks sharp! Very clean and a great color too. Welcome!
Instagram: @azurblumach1
Old 01-24-2019, 12:03 PM   #7
nobringer's Avatar
Will the bilsteins be ok with the steeda lowering springs?
Old 01-24-2019, 12:03 PM   #8
nobringer's Avatar
Thank you
Old 01-24-2019, 12:04 PM   #9
nobringer's Avatar
Appreciate all the advice ! Will the bilsteins beok and work well with the steeda lowering springs?
Old 01-24-2019, 12:27 PM   #10
nobringer's Avatar
Adjustable or non adjustable rear lower control arms?
Old 01-25-2019, 05:31 AM   #11
nobringer's Avatar
What would be a good tune for my car? The last owner gave me a hand held tuner when I bought the car but I know nothing about doing tunes
Old 01-25-2019, 05:32 AM   #12
nobringer's Avatar
I’d like to do a time before I add anything else
Old 01-25-2019, 11:59 AM   #13
Lorraine's driver
ab_mach1's Avatar
Bilsteins would be great for any springs. I don't know if I'd buy adjustable rear LCA's unless I had a reason; like lowering the rear even more than the springs do or dialing in the rear for track use. Mainly because they cost more than non-adjustable LCA's. For the front, you would want to check to see what options you have if getting a new K member vs. keeping the stock K member. Maximum Motorsports has great suspension parts for newedge and foxbody cars. Whether you buy their parts or not, their website is chock full of information on suspension that can help you decide based on what you're planing to do with your Mustang. As far as tuning goes, make sure the tuner is unlocked. I'm not sure how to determine that, but I'm sure someone knows on here. I would then go with a tune from someone other than Bama (American Muscle). I'm sure someone will provide a list of tuners regularly used on here. I have an email tune from Lasota Racing. They have many years of tuning modular Ford engines.
Old 01-25-2019, 01:31 PM   #14
nobringer's Avatar
Thanks for the help I’ll have to look into more tuning. And I was figuring on the non adjustable just wanted to check.
Old 01-25-2019, 05:57 PM   #15
KATO's Avatar
Welcome Aboard from Cutler Bay, FL.
2007 GT PREMIUM. CUSTOM TUNE by "MUSTANG SPECIALTIES". STEEDA INTAKE, MAGNAFLOW COMPETITION FULL EXHAUST, LT. HEADERS, X PIPE, STAGGERED WHL 22X8.5F-22X10R.
Old 01-26-2019, 04:34 AM   #16
nobringer's Avatar
Thank you
Old 04-14-2019, 07:15 PM   #17
revolver92's Avatar
That's a nice find, very neat looking and low mileage.
revolver92 is offline   Reply With Quote
First new car, first mustang, first ford Sportsman New Member Introductions & Greetings 21 11-20-2015 02:59 PM
First clay bar, first wax, first wash...glamour shots! Guard 5.0 2015+ Mustang GT 15 06-29-2015 09:58 AM
First Mustang...First Ford...First Car This Awesome! Debster New Member Introductions & Greetings 13 04-28-2013 12:30 PM
First Post, First Car, First Mustangg EdgeLivin New Member Introductions & Greetings 14 04-03-2012 12:49 PM
first car, first mustang gt /w pics Rich_Guy New Member Introductions & Greetings 9 06-15-2009 10:37 AM
» Premium Vendor
11:13 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
