CAI, Exhaust, Pulley change - Mustang Evolution
Go Back   Mustang Evolution > 1979-Current Mustang GT || Tech and Talk > 2005-2010 Mustang GT
Old 09-30-2017, 12:22 AM   #1
Hello, I just purchased this stock 2008 Roush Trak Pak, amazing that in 2008 the car did not get a CAI, considering the Roush package on this car cost $31000.
I'm thinking I initially would like to do a CAI, something with the exhaust, a pulley change, and a tune.
The car has cats, an H pipe, and the axle back Roush mufflers, it sounds okay but I want to try and get a deeper, throaty, louder growl.
The car will be registered and spend a lot of time in a state that does not require emissions, someone mentioned to me to have the honeycomb interior of the cats knocked out, that alone would increase the sound, thoughts on that?
Or would most recommend leaving the cats alone or deleting them completely?
I would like to consider headers but somebody told me this interesting Theory, is it true? They said headers are good for adding high-end horsepower, but not low-end torque, that stock manifolds will give you more low-end torque than headers, true-false?
I'm interested in more torque than horsepower.
I'm guessing that a system designed and made in 2008 is considered old and a lot has changed since then. I've listened to the new Roush extreme performance exhaust video online that uses resonators instead of mufflers and I really liked that sound, and I'm guessing that the car had stock manifolds and cats. So should I do headers or not? Should I keep the cats or delete them? Should I leave everything as it is and just get the new resonators and see what happens? What is everybody else out there using when they want a low deep growl? I'm not opposed either of doing a full exhaust system if people have some good opinions of systems they've used.
Along with that may I have your opinions on which CAI to get?
Seems that there's a lot of people out there changing their pulleys from the stock setup, again my goal is more low-end torque than high-end horsepower, someone mentioned to me that I should consider changing the crank pulley instead of the supercharger pulley to get more torque, What is everybody's opinion and Truth on that subject of pulley change?
Also, I hear of people changing their thermostats, can someone tell me why and should I do that?
In a couple of the pictures that I'm going to attach you can see where the exhaust goes up over the axle, there's a pretty good kink in the pipe, is that just how it was done in 2008? or is it still that way today? I was under the impression you wanted your exhaust to flow as unobstructed as possible, will I need to get a new full exhaust to fix that?
Anything else that is recommended that is not an in depth motor mod?
Thanks, Everyone.
ID:	244290   Click image for larger version
ralfano is offline   Reply With Quote
Old 09-30-2017, 11:23 AM   #2
I wouldn't invest in that M90. If you're on a Budget look into the VMP 1.7L TVS. If not look at the Roush or VMP 2.3L TVS. Both the 1.7L and 2.3L will make more efficient power than a pulley and ported M90. They'll also max out your engine with just a pulley swap and injectors.
As for mufflers, Roush extreme axel backs have my vote. Only issues is drone. If that bothers you don't get them.
Pick your poison.
Recon is online now   Reply With Quote
Old 09-30-2017, 12:20 PM   #3
Pick your poison.
Recon, thanks for your honesty, I wasn't expecting that answer, could you fill me in a little more since I'm a newbie.
Are you more or less saying in a certain way that instead of doing all those other modifications I should leave it as is and I will gain much more horsepower and torque by changing the supercharger alone?
I could live with the exhaust the way it is at the moment.
And I noticed quickly that some supercharger kits come with a CAI.
So am I understanding you correctly that with a few modifications to my M90, the M90 is a entry level charger from Roush that gets maxed out quickly?
I definitely am on a budget but if you're saying I start adding up all those other little modifications whatever they add up to, and how much more in the end might I have to put in, give me a rough idea of what a VMP 1,7L TVS, installed will run me? And what will it do over my present stock situation for numbers.
I never even considered changing the supercharger on a car I just bought a week ago, lol...
But as I said I'm a newbie and didn't have a clue of the M90s limitations, but in the end if that's really the better route to go I'm all ears and thank you.
Old 09-30-2017, 12:21 PM   #4
Rapinator126's Avatar
Pulley, full exhaust and a more efficient heat exchanger.
Just get the VMP 500hp kit. And a heat bigger exchanger, longtubes. You will be happy
Sent from my SAMSUNG-SM-J727A using Mustang Evolution mobile app
Old 09-30-2017, 12:45 PM   #5
Well if I'm looking at the website correctly, they have that set up on sale for $600 off.
down to $2099, Then I have to add a tuner at a minimum correct?
Old 09-30-2017, 02:48 PM   #6
The 500hp kit is $1000 and comes with a tune
cai, exhaust
Cody, did you change to a smaller pulley? WheelStander 1996-2004 Mustang GT 6 08-18-2012 04:55 PM
CAI & Oil Change Spots BlackHorse1911 2011-2014 V6 Mustang 2 07-18-2012 05:57 PM
Polished water pump pulley and alt pulley for 01-04 4.6 2v Everett Mustang Parts for Sale and Wanted 1 03-17-2011 02:52 PM
cai and pulley mustang0386 Pre-2005 V6 Mustang 8 11-24-2006 10:08 PM
change exhaust mustang0386 Pre-2005 V6 Mustang 2 11-15-2006 01:13 PM
» Premium Vendor
05:25 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
