2006 GT - Mustang Evolution
Go Back   Mustang Evolution > 1979-Current Mustang GT || Tech and Talk > 2005-2010 Mustang GT
Old 05-12-2019, 08:20 AM   #1
2006 GT
First thanks for the membership to this group. I grew up a motor head. My first car was a 67 Fastback K. Dad owned an auto shop. My 15 yr old son has worked and saved and bought this car. It’s as close to perfect as you can get for a 2006. Did not run. If you jumped the fuel pump relay it would run. No command to the relay to run from the computer. I sent the computer off and had it repaired. They said it had some cold solder joints. I’m in the building automation business and build my own airplanes. What they told me just didn’t add up. But I got it back and installed and got the same results as before. I was getting random codes as well. But 20 of them. Tells me a computer, power or ground issue. I took every connector I could find under the hood apart. Even pulled fuse panel off. No corrosion at all. Put it together and it ran fine but codes came back. They will clear and come back in a day. Car runs great though. I have read of a junction behind the rich kick panel. Has anyone had a similar experience? Could the dealer dive a definitive conclusion on the PCM? Thanks is advance.
10
20
135
141
155
161
171
174
443
446
Dewey
Dewey.elsik is offline   Reply With Quote
Old 05-12-2019, 01:33 PM   #2
New development. Cleared codes and it will not start now . Same issue as I started with. I’m beating my head bloody here.
Old 05-12-2019, 02:39 PM   #3
10
20
135
141
155
161
171
174
443
446
Dewey
I have same car, 4.6 lowered, 20's(by other owner), mint, 5 speed auto, 67K orig - so above are the codes??? Sure sounds like a ground issue.
P.S. Howdy neighbor, I'm in Hutto
Heinz
06 GT, auto, 65K
hfca is offline   Reply With Quote
Old 05-12-2019, 03:31 PM   #4
I live over at the private airport north of the landfill. Swing by sometime.
Which car should I get? A 2006 Corolla S, 2006 Mazda 3i Sedan, or a 2005 Lancer Es? brant General Car Discussion 5 07-19-2011 04:23 AM
MEVO WHATS UP!!>!>!>!>!?!??!?!>!>!>!>! Knight F Mohawk The Bar 0 06-23-2011 08:19 PM
Which should I buy? A 2006 Nissan Altima SL? Or a 2006 Ford Mustang v6? sutton General Car Discussion 3 03-01-2010 09:57 AM
2006 GT heads on a 1999 GT???? Isaac 1996-2004 Mustang GT 14 07-19-2007 08:05 PM
» Premium Vendor
05:30 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
