New edge headlight fog problem - Mustang Evolution
Go Back   Mustang Evolution > 1979-Current Mustang GT || Tech and Talk > 1996-2004 Mustang GT
Old 03-29-2019, 11:49 AM   #1
69ponyxprs's Avatar
Does anyone make a good headlight fir the SN95 new edge cars that doesn’t get hazy over time? I am so sick of pulling my headlights every year or so to sand them buff them and recoat them. There’s gotta be a better way. This sucks!
69ponyxprs is offline   Reply With Quote
Old 03-29-2019, 12:08 PM   #2
Lorraine's driver
ab_mach1's Avatar
Are these your factory set or an aftermarket set?
Instagram: @azurblumach1
Old 03-29-2019, 12:26 PM   #3
69ponyxprs's Avatar
As far as I know factory
Old 03-29-2019, 01:33 PM   #4
Lorraine's driver
ab_mach1's Avatar
Yeah, once you restore them, the clear coat is basically gone. That's where the ultraviolet protection is. The next time you restore them, you could try to following that up with a couple coats of clearcoat spray. That would help. The other thing you could try is apply a good paint sealant on them every month or so. Mine are new, but mine is also my weekend car, so it shouldn't be an issue. Even so, I coat mine with a paint sealant once or twice a year.
Old 03-29-2019, 01:47 PM   #5
69ponyxprs's Avatar
The restorer I use had a clear coat that you apply after buffing. It doesn’t last that long though. I can’t believe there’s no one out there that makes an assembly that doesn’t fog up line this. Ridiculous when you consider how much these pieces cost. Sort of pisses me off.
Old 03-29-2019, 11:28 PM   #6
Lorraine's driver
ab_mach1's Avatar
Speaking of fogging up...my LMR clear corner headlights fogged up inside terribly. I ended up getting a second set which fogged up as well. I ended up using 100% silicone caulk and sealed them up myself. I agree, it's ridiculous that these people can't put together a headlight housing. I nearly pulled the trigger and bought a set of Ford OEM housings hoping they would be as good as the original set as far as fogging up and lasting at least 10 years before hazing over. Those are like $450 lol.
Old 03-30-2019, 02:20 PM   #7
tohhamilton's Avatar
I had this issue with my 99 Stang. I removed the headlight assemblies, sanded them down in progression, and layed 3 coats of clear on them. That was 2 years ago. They still look brand new. The car isn't garage kept.
tohhamilton is offline   Reply With Quote
Old 03-30-2019, 04:50 PM   #8
Westcoast408's Avatar
Where do you order this clear coat spray?
Sent from my SM-G920T using Mustang Evolution mobile app
99 Mustang GT F.R 3.73s, MGW Short Shifter, BBK Cai, BBK 70mm Throttle Body, Mach 1 Chin Spoiler, SR Lowering Springs, Koni shocks and struts, Mach 1 Grill Delete, Black Billet Fuel Cap, Trick Flow 75mm Plenum, Raxiom Smoked Tail lights, Magnapack Mufflers
Westcoast408 is offline   Reply With Quote
Old 03-30-2019, 05:24 PM   #9
69ponyxprs's Avatar
I was going to ask the same thing. What type of clear are you using?
Old 03-30-2019, 06:16 PM   #10
I dont remember the exact brand or type. I picked it up at an O'Reilly's auto parts store. My last (3rd) layer I sprayed on a bit heavy.
Old 03-31-2019, 11:48 AM   #11
edit, thought it was for 94-98 cars.
Get the LRS reproduction headlights and then seal them with clear silicone around all the seams. Have not had any issues with this method.
Old 04-01-2019, 01:40 PM   #12
69ponyxprs's Avatar
Thanks everyone for the tips!
Old 04-01-2019, 01:54 PM   #13
akumaJR's Avatar
Raxiom
akumaJR is offline   Reply With Quote
Old 04-02-2019, 02:42 AM   #14
Originally Posted by akumaJR View Post
Raxiom
He said he DIDN'T want a product with QC issues...
Old 04-02-2019, 10:30 AM   #15
Lorraine's driver
ab_mach1's Avatar
Old 04-02-2019, 12:23 PM   #16
69ponyxprs's Avatar
I hear so many negative comments about raxiom. I don’t see how they can stay in business with that rep....
Old 04-03-2019, 12:26 AM   #17
Because ppl are idiots.
Old 04-03-2019, 03:04 AM   #18
69ponyxprs's Avatar
Lol. Scotty you crack me up. 😂
Old 04-14-2019, 07:09 AM   #19
Revvv's Avatar
Originally Posted by HomelessDog View Post
my car came with blacked out one's from AM and what i assume is the clear coat is peeling off. Have the stock headlights and they are very foggy. has anyone found a good pair for a reasonable price?
Lights from LMR.
Sent from my SM-G975U using Tapatalk
Old 04-16-2019, 06:50 AM   #20
Speaking of Raxiom, I have their Icon taillights for my 2002 GT. I had an issue with them initially - some of the mounting studs on them loosened and then were turning inside their threaded holes when I tried to tighten the nuts - but, that was only because I had problems with the (non-Raxiom) sequential turn signal harness I was trying to use with them, and had to install/remove the taillights like ten times. At first, American Muscle was hesitant about replacing them, but I got Raxiom involved, and they must've told AM to go ahead and replace them, because AM sent me a new set right away. I got a sequential harness from a different manufacturer, and installed the replacement Raxiom taillights. That was more than three years ago, and I haven't had a single issue with them.
Sent from my Phone 2 using Mustang Evolution mobile app
dmw_4814 is offline   Reply With Quote
Raxiom Halo headlight/fog light Intensity sguevara 2011-2014 V6 Mustang 40 03-06-2015 12:44 PM
headlight/fog lamp tint HERGTSPOT 2011-2014 Mustang GT 6 08-10-2012 06:08 AM
Headlight Fog light switch HELP!!! Fox 5.0 1979-1995 Mustang GT 11 07-08-2012 04:29 AM
2008 Edge drive shaft problem 67mustang97 General Car Discussion 0 06-16-2012 05:37 PM
Headlight and center fog lights question BossFiveOh 2011-2014 Mustang GT 16 05-13-2012 08:03 AM
» Premium Vendor
11:04 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
