Mach1 won’t start - Mustang Evolution
Go Back   Mustang Evolution > 1979-Current Mustang GT || Tech and Talk > 1996-2004 Mustang GT
Old 03-30-2019, 05:18 PM   #1
csm5652's Avatar
Region: Maine
Mach1 won’t start
Hi guys, I own a 2003 white Mach1 I’ve owned since new. I was taking it out of storage and I started it up it ran a little rough brought up the rev’s and it seem to clear out notice some white smoke and cleared just a short moment. Was letting it run and I noticed a light pop from exhaust and a stumble. Went over to bring rev’s up and it died. Went to restart and a no go. Checked fuse for fuel pump it’s good, I also check power to pump and that was in range. Can’t hear pump humming. I did check relay because I thought since I had power to fuel pump relay was working. I checked the inertia switch and it was fine. I guess my next step is fuel pressure tester. Also am I right about the relay. Little back ground on my car all stock except for tune and exhaust. The car did have any codes, also only ran for 10 min.
About 8 years ago almost to the day, the fuel pump died. Is there a problem with these stock fuel pumps, they put the stock one back in from Ford and was done by a dealership. . Also if there is a better which one will work and last the longest. Thanks
csm5652 is offline   Reply With Quote
Old 03-31-2019, 08:47 AM   #2
Yes. A fuel pressure test should be your next step.
Do you often run the gas tank down below 1/4 tank before filling it up?
Old 03-31-2019, 04:28 PM   #3
csm5652's Avatar
Region: Maine
Some times all depend just seems like 8 years with this fuel pump is the manic number. Going to pick up a tester tomorrow after work and test it.
Old 04-01-2019, 10:39 AM   #4
Lorraine's driver
ab_mach1's Avatar
Do you put some sort of fuel stabilizer in your tank prior to putting her away for the winter months? I put Royal Purple Max Clean in mine with a full tank and drive it for a couple of days to let it get throughout the fuel system. I started doing this in my lawn mowers and my snow blower. They all start on the first pull in the spring since doing this. I think this is especially importable now that they put ethanol is the mix. I still need to get a battery tender, but since doing this, my Mach runs so much smoother when I start her up after sitting for weeks and months at a time.
Instagram: @azurblumach1
Remote start/push to start GT_Man 2011-2014 Mustang GT 9 01-31-2015 11:57 PM
Thought I'd share pics of my successful Push-to-Start/Remote start install! Jordan.Cortina General Mustang Discussion 32 01-30-2015 08:29 AM
18x9 mach1 POLISHED rims...flawless rims! ready to ship! Autobadges.com Mustang Parts for Sale and Wanted 5 09-30-2004 08:50 PM
Mach1 Gone Wild - Newly Painted KrazyPony The Bar 23 12-14-2003 12:42 PM
mach1 chin spoiler drmac The Bar 3 10-21-2003 12:13 PM
» Premium Vendor
05:18 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
