A/C Evap Replacement - Need Opinions - Mustang Evolution
Go Back   Mustang Evolution > 1979-Current Mustang GT || Tech and Talk > 1996-2004 Mustang GT
Old 04-30-2019, 10:12 PM   #1
I just replaced the floor carpeting in my 2002 GT. I spent just over $300 (including shipping) to use NOS OEM Ford carpeting (Dark Charcoal) that I was lucky enough to find at Vintage Parts, in Wisconsin. Since my interior is still half apart, and since I don't want a 17 year old (probably; no idea if it was ever previously replaced) heater core leaking all over my brand-new carpeting, I've decided to pull my dash and remove the evaporator case, so I can install a new heater core (it's not currently leaking; this is just preventive maintenance).
Since I'm going to pull the evaporator case for the heater core, I decided it would probably be prudent to also replace the evaporator core, as that's probably 17 years old, too. Mind you, my air conditioner is functioning just fine, currently, so I'd be doing this also as preventative maintenance. I've replaced a leaking heater core in a '97 T-Bird, and while it wasn't super hard, I'd prefer to not have to remove my Mustang's dash a second time, should the evap core go bad, later on.
Opinions? Should I bother with the evap core while I've got the case out for the heater core, or am I being WAY too particular?
Has anyone on here ever replaced an evap core on these Mustangs? I understand the case is sealed - can it be opened, and then resealed, afterwards?
Thanks!
Sent from my Phone 2 using Mustang Evolution mobile app
dmw_4814 is offline   Reply With Quote
Old 05-01-2019, 09:00 AM   #2
It's been a while since I did mine, and I didn't replace the evaporator, but I believe that the evaporator is no problem to access.
I haven't had any problems with the evaporator, but I did regret not replacing it while the dash was out of the car.
I don't think that you are being overly particular.... disassembling half of the interior is no small task!
Good luck!
Old 05-08-2019, 04:01 AM   #3
I've never had to do the evap or heater core and I've had some old SN95s... Now that I've said that. Yeah if you want to do them while the dash is out that's the easiest time.
EVAP issuing plaguing Mustangs! fluffyGT06 2005-2010 Mustang GT 0 12-01-2011 12:48 PM
1996 Mustang V6 3.8l Evap Code xxxchaos 2.3 Mustang 0 07-30-2011 03:24 PM
1996 Mustang P1443 Evaporative Emissions (EVAP) Canister Purge (CP) Valve Brent Pre-2005 V6 Mustang 33 01-30-2011 09:32 PM
2004 GT EVAP Questions SSgt Dan 1996-2004 Mustang GT 16 09-25-2009 02:20 PM
Evap leak Small jmarcinko00gt 1996-2004 Mustang GT 6 09-03-2008 11:26 AM
» Premium Vendor
03:39 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
