Convertible top doesn't go down easy - Mustang Evolution
Go Back   Mustang Evolution > 1979-Current Mustang GT || Tech and Talk > 1996-2004 Mustang GT
Old 09-11-2019, 10:04 PM   #1
runvsofthisbull's Avatar
Good Evening,
So I have an 02 convertible and just replaced the motor, lines, and shocks for the convertible top since the old ones were leaking. Now the top goes up fine, however when the top is up and I try to put it down it requires a little help getting off where it clamps down on the windshield. I am having to essentially push the top up and then it goes down fine. I will say I do see a tiny bit of air in the line an inch or so, but I don't think that's the issue since the top goes up just fine. Any thoughts/other parts that could be bad causing it to do this?
Thank you.
2002 True Blue V6 to GT Vert
[email protected] as an auto 3.8
2.15 60', [email protected], [email protected] as a 5spd SOHC 4.6
Old 09-12-2019, 08:52 AM   #2
jkeaton's Avatar
You need to bleed the system thoroughly.
jkeaton is offline   Reply With Quote
Old 09-12-2019, 10:01 AM   #3
Revvv's Avatar
This is the answer.
Sent from my SM-G975U using Tapatalk
Old 09-12-2019, 10:27 PM   #4
Copy that guys.
I did it like 10 times putting the top up and down. I just can’t seem to get this 1-3 inch gap of air out. Any advice? Also do you keep the little plug from the pump out during this time or no?
Old 09-13-2019, 12:21 AM   #5
jkeaton's Avatar
Put the plug in or fluid will come out.
» Premium Vendor
03:23 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
