Boosted spark plugs. - Mustang Evolution
Old 10-11-2019, 11:44 AM   #1
tman1020's Avatar
What plugs are you guys using in your 05 –09 boosted Gt set ups?
I am going to go with the heat rain zero just not sure what brand
tman1020 is offline   Reply With Quote
Old 10-13-2019, 11:40 PM   #2
If you are running less than 10-12 lbs of boost, the standard Motorcraft or Autolite platinum plugs, in the appropriate heat range, will work just fine.
Above that, you should switch to a conventional non-resistor spark plug.
Old 10-14-2019, 12:27 AM   #3
tman1020's Avatar
[QUOTE=straybullitt;4261731015]If you are running less than 10-12 lbs of boost, the standard Motorcraft or Autolite platinum plugs, in the appropriate heat range, will work just fine.
Above that, you should switch to a conventional non-resistor spark plug.[/
thanks. I ordered a set of brisk heat range zero. We’ll see how they go.
» Premium Vendor
06:44 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
