Auto adjusting rear brake calipers question - Mustang Evolution
Old 05-19-2017, 06:29 AM   #1
Hello All,
I have a 2012 MT82 Mustang V6 with 90300 miles on it. I was having an issue with low brake pedal. The handbrake was loose and how much ever i tightened it the rear passenger side wheel kept turning. So i figured the auto adjuster had gone bad in the caliper and replaced the caliper. Now after a few weeks its the driver side rear caliper that seems to not hold the wheel when the handbrake is pulled. Its not as bad as the first one but its on the verge of giving up. I noticed this when i started to notice that the pedal is going a little more lower than normal.
My question is although i did not see any screws on the caliper to adjust the internal mechanism for auto adjusting, is there any way i can adjust the driver side caliper or replacing is the only option?
Note: I have adjusted the lever from the inside of the car and have bled the brakes. I m sure there is no air in the system.
FordMustang12 is offline   Reply With Quote
Old 05-19-2017, 07:02 AM   #2
While searching for a solution i found this link. I will try this out today rear handbrake caliper out of adjustment - SEAT Cupra.net - SEAT Forum . I will keep you guys posted.
Old 05-19-2017, 08:41 AM   #3
Sounds like you may have two different issues going on. The brake pedal itself is lower than normal and the parking break is not working? If there is no air in the system you could have a worn out master cylinder is there any visible leaked around the calipers? . Not uncommon a bad master cylinder to show up after bleeding brakes. As far as the e brake not working with everything adjusted properly it might be bad threads like the article says.
Mhenry13 is offline   Reply With Quote
Old 05-19-2017, 08:54 AM   #4
Here is a video about these calipers
---------- Post added at 02:54 PM ---------- Previous post was at 02:54 PM ----------
It sounds like from this it could just be an issue with the adjuster
Old 05-19-2017, 09:00 AM   #5
This is the exact thought i had when i was diagnosing the problem and i checked everything and nothing seemed to be wrong. I scratched my head for more than a week on this. The master cylinder is okay, no leaks and it holds pressure. The reason why the handbrake and low pedal issue is related is because the internal adjuster when worn out/not working the pads don't stay close to the disc. They move far away from the disc. The internal adjusting mechanism is the one that keeps the pad closer to the disc. Due to this you need to push the pedal in further to get that travel.
Old 05-19-2017, 09:03 AM   #6
I came across this video but it looks like ford's mechanism is a little different that audi. For ford the piston directly screws in on a screw but for audi it has a small circle thing running behind the piston that pushes it.
Old 05-19-2017, 05:24 PM   #7
For those who are curious to know I ended up changing the caliper today and now everything is normal. The piston in original caliper wouldn't come out when the handbrake was applied. This pointed towards the internals being screwed up for auto adjusting mechanism.
Old 05-20-2017, 06:18 AM   #8
This is good to know. Glad it's fixed
Painting my brake calipers question... whitboy82 Mustang Paint, Appearance & Detailing 6 06-01-2015 04:11 PM
adjusting the parking brake cable i973eat1 1996-2004 Mustang GT 3 12-25-2014 03:16 PM
Brake Calipers Mustang 4pt0 2005-2010 V6 Mustang 21 04-05-2012 02:09 PM
Brake Calipers Topxshelfxtre Pre-2005 V6 Mustang 8 04-11-2010 09:49 PM
rear brake install question kevinsm Pre-2005 V6 Mustang 4 03-16-2004 10:01 AM
» Premium Vendor
05:19 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
