Fuel Pump/Saddle Tank Issues... - Mustang Evolution
Old 11-03-2018, 07:30 PM   #1
Mirage's Avatar
Can't seem to find much info on this so I thought I'd ask the forum.
I replaced my 11 year old stock fuel pump a while ago with another assembly from Spectra Performance. Since then I can't seem to get the jet pump to work. I get down to about 3/8 of a tank (indicated on my fuel gauge or about 224 miles), and I run out of gas. I pull the pump and the drivers side is empty, and the passenger side is pretty much full. (like 4 or 5 gallons left). I've pulled the pump out several times, checking for possible leaks and/or cracks in tubing, anything. But I see no reason why it shouldn't work. Does anyone know if the o-rings on the quick connect piping are replaceable? or do I have to find another transfer pipe (which I see no part number for on Ford parts web sites or drawings)?
Any help, thought or suggestions would be greatly appreciated.
Mirage is offline   Reply With Quote
Old 11-05-2018, 08:29 AM   #2
Possibly the tube cracked where you cannot see it especially since it happened right after. Did you pull the passenger side of to make sure that side is still attached ?
Sent from my SM-J327P using Mustang Evolution mobile app
Mhenry13 is offline   Reply With Quote
Old 11-05-2018, 09:38 AM   #3
Mirage's Avatar
I thought of that. So I bought new connectors and tubing and made a new one, still has the same problem. Also made sure there was no obstruction in the vortex tube and such, found nothing. I'm out of ideas.
Old 11-05-2018, 06:35 PM   #4
You may have something wrong with the transfer pump or the level sending unit on the transfer side . I believe they have on just like the main pump side . Either the pump is bad or something is causing it to think that side is empty causing it not to work
Old 11-05-2018, 06:49 PM   #5
Mirage's Avatar
You are correct, they do have a level sending unit on the passenger side jet pump. which is really just a plastic tube that goes to the bottom of the tank, with a quick connect male fitting on it to accept the transfer tube. I will look into the possibility that the level sender is bad. Thanks.
Old 11-06-2018, 09:21 AM   #6
You're welcome. Let us know what it ends up being. I am sure we are all curious about this
Old 11-06-2018, 09:23 AM   #7
Also make sure the after market pump assembly doesn't have anything stopping the fuel flow especially since the issue started right aftet
How to drain fuel tank from the fuel line and fuel rail nuacr0s Roush Mustang 1 03-25-2017 08:43 AM
New fuel pump / jet pump problems Mirage 2005-2010 V6 Mustang 2 12-31-2016 10:06 PM
trade brand new corbeau seats for 03-04 cobra tank fuel pump assembly Tomb1987 1996-2004 Mustang GT 9 05-19-2013 04:46 PM
04 GT gas tank and fuel pump Xaperez100 Pre-2005 V6 Mustang 2 04-29-2013 08:57 PM
fuel tank and radiator issues... mustangmare Pre-2005 V6 Mustang 1 11-01-2004 07:09 PM
» Premium Vendor
08:56 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
