Vibration in idle and gets worse when in gear after header install - Mustang Evolution
Old 11-04-2018, 02:00 PM   #1
MustangsForEver's Avatar
Hello everyone i've got a bit of a weird issue that I can't seem to figure out.
I recently brought my car into a shop to get my shorty headers installed after my DIY failed attempt caused the EGR seal to break and that came with check engine lights and running lean codes and I just gave up. Anyways I brought it to a shop my neighbor owns and he was able to do a custom install because the headers didn't quite fit right but he and his crew did a good job from the looks of it. Everything runs great and sounds amazing but now I have a really annoying issue in idle.
When the car is in park and idling it is perfect at first but a vibration slowly comes up and it has a mild noticeable vibration that can be felt everywhere. When it is in gear like Drive or Reverse that is when the vibration feels like something might be getting damaged and is pretty rough. It ONLY happens like that when it is not moving. The second I start to drive it is perfectly fine no problem.
I know its not motor mounts because this only started happening right after the header install. I don't know how it could be the exhaust rubbing on something because it gets way worse when in drive or reverse at a stop and the RPMs do not change.
Things about the car that might help:
94k Miles
2010 V6
BBK Cold Air intake
PaceSetter Shorty Headers
Flowmaster American Thunder Exhaust
His explanations for the vibration do not make sense because he said that it was probably rubbing because the headers were not a perfect fit that is why I am here.
Is there anything I could do to better diagnose this?
I appreciate any help
This is the car https://imgur.com/ZSgUvYF
MustangsForEver is offline   Reply With Quote
Old 11-06-2018, 09:20 AM   #2
Vibrations can be tricky to figure out. They need to be pin pointed to source . I would be highly suspect of the new headers. Any exhaust rubbing or touching body will send vibrations though entire car
Sent from my SM-J327P using Mustang Evolution mobile app
Mhenry13 is offline   Reply With Quote
Old 11-06-2018, 10:04 AM   #3
Strange Mud's Avatar
why elim motor mounts as culprit....did they loosen/remove them to get headers in?.
04 mustang GT idle surging,car shaking worse with a/c on jimmyi.salcedo 1996-2004 Mustang GT 19 09-15-2017 07:34 PM
Vibration after clutch install VertGT 1996-2004 Mustang GT 30 10-18-2013 05:42 PM
Rough idle before throttle body cleaning, worse after 11CharlesB Pre-2005 V6 Mustang 7 09-10-2013 06:21 PM
94 Mustang runs worse after CAI & coil install, Need suggestions Mustang52 1979-1995 Mustang GT 5 09-21-2012 11:22 PM
Idle is just getting worse katie_ann 1996-2004 Mustang GT 3 09-03-2009 04:26 PM
» Premium Vendor
12:38 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
