Shaking While Braking Mystery continues. - Mustang Evolution
Old 01-15-2019, 11:29 AM   #1
Angry Shaking While Braking Mystery continues.
So, I own a 2010 Mustang V6 premium with 20 inch wheels. It has 75xxx miles on it and drives like a Champ. It is also my daily driver and over a period of time I have noticed an increase in the steering wheel shake while braking. Higher the speed I brake more the steering wheel shake it was. So, I have done following till now and got following results so far:
1) As a rule of Thumb, I got all the 4 wheels re-balanced and it helped with removing the steering wheel shake due to wheel imbalance while driving from say 55 to 65 mph but didn't help steering wheel shake while braking.
2) Got all 4 new rites installed along with the Wheel re balancing. So, getting all 4 new tires helped with the steering wheel stiffness a little bit and the ride is now smoother, but didn't help steering wheel shake while braking.
3) Replaced all 4 brake rotors with Power stop Z26 performance rotors. And also bled all 4 brake lines like hell and used DOT4 brake fluid instead of DOT3. Largely reduced the steering wheel shakes while braking, So now, I didn't have any steering wheel shaking while braking below 50mph. But steering wheel still shaking while braking over 50mph.
4) Replaced all 4 Brake calipers with Power stop performance Brake Calipers. Did not help with anything.
Now, with all of the above parts replaced and putting in a **** Loads of Money and time in this stupid Issue, I still have Steering wheel shake while braking above 50mph. While braking below 50mph I feel absolutely Nothing at all. It does feel like my steering wheel shakes more while I brake lightly and does not so much when I brake with full force.
I recently got it Check from two mechanic Shops and one of them told me that there is nothing wrong under the Car, my tie rods and control arms looks OK. However, the second mechanic told me that my Lower control arm shows some signs of wear and I should try getting them both replaced along with the Ball joints.
Now, I am on the brink of Braking off....... It is hard for me to believe any mechanic saying anything. Please Help !!! Should I go ahead and get my lower control arms and ball joints replaced???
This is very frustrating for me to keep on putting more and more money over and ever again into the same stupid problem in a car which is supposed to be well built, while my 2003 Nissan has 140K+ miles on it and not even a single problem. Brake Pads are the only thing ever replaced on it and that's about it, oh and it brakes wayyyyy better than mustang. I feel ashamed of buying an American car. Please help !!!
ryu.rules is offline   Reply With Quote
Old 01-15-2019, 07:45 PM   #2
This is why it is important to find a good, honest, mechanic. And once you find this illusive "unicorn" mechanic, you treat him like he is your brother. Better than your brother! You send him Christmas cards. Invite him and his family over for dinner a few times a year. Bring fresh baked cookies down to the shop every once in a while...
If your steering wheel is shaking when you apply the brakes, something is worn out in the front end of the car. Since you have already eliminated some of the more common causes, I believe that the only things left are the control arm bushings, and the front wheel bearings. And depending upon the mileage on your car, it could be either.
Old 01-16-2019, 04:06 AM   #3
Rubber bushings in the control arms are a prime culprit for any steering wheel shake. At 9 years old they are probably dry rotted and the balljoints and bearings are due too at this point. Its not a hard swap to do DIY if you have basic hand tools but not everyone does.
Inner and outer tie rods can also cause issues if they are worn.
Extreme vibrations while braking FordMustang12 Mustang 101 - Tech Basics | Ask an Expert 14 10-28-2018 08:46 AM
Mystery continues JB_MUSTANG_V6 1996-2004 Mustang GT 17 09-09-2013 08:59 AM
Shaking Feeling while driving 92mustang2.3 2011-2014 Mustang GT 16 05-05-2013 10:27 PM
Shaking while high speed turns mrkrabz 2011-2014 V6 Mustang 17 12-20-2012 11:14 PM
Popping sound while braking... 12GTstangCS 2011-2014 Mustang GT 4 11-29-2011 12:55 PM
» Premium Vendor
09:47 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
