Problems with cooling system - Mustang Evolution
Old 01-19-2019, 04:53 PM   #1
Been having a problem with the heat in my 2008 Mustang for about a week now. The hear was taking a really long time to heat up. I checked and the coolant reservoir was empty so I filled it up. Drove the next day and everything seemed fine (heat got hot really quick). The next day, however, I was driving and notice steam coming out of the engine. When I opened the hood up antifreeze was coming out of the cap. I removed the thermostat and it was covered in rust and bad. I replaced the thermostat and cap just to be sure. I filled it back up and took it for a short drive. Coolant was still blowing out of the cap. Someone suggested I might have a blockage somewhere which is causing the pressure to go way up. I flushed the radiator out and the antifreeze was reddish brown. The reservoir was the same way. After the flushing I filled it back up again and took it for another test drive. I got like 2 miles when the car started to buck and then the wrench light turned on. I turned around and went back home. With all the rust I'm thinking either a severe blockage in the radiator or maybe a blown head gasket. I see no leaks anywhere (oil or coolant) expect for the antifreeze coming out of the cap and that only occurs wen driving. If the car is idling I have no coolant leaking from the cap. Also, during the test drives the temp gauge would go full hot for a few seconds, come back down to the middle and do this several times. Thoughts anyone?
bucktaylor100 is offline   Reply With Quote
Old 01-19-2019, 07:11 PM   #2
Is the radiator cooling fan turning on when the engine seems to be overheating?
Old 01-19-2019, 07:25 PM   #3
Yes the fan is turning on. The oil doesn’t look right either. I’m posting pics of both the oil from the cap and antifreeze which was just changed.
ID:	257939   Click image for larger version
Old 01-19-2019, 07:48 PM   #4
I’m convinced it’s a blown head gasket. If I run the engine with the coolant cap off I see bubbles which someone told me is a sign of air in the coolant system.
Old 01-19-2019, 08:18 PM   #5
From the looks of that oil cap your getting coolant in your oil ! Most likely you’re right about head gasket .
Ryderz123 is offline   Reply With Quote
Old 01-19-2019, 08:19 PM   #6
Definitely a blown head gasket.
Old 01-20-2019, 03:11 PM   #7
Beviking's Avatar
Yup, unless you put lithium grease or mayonnaise in your oil?
'12GT Premium, Roush TVS & BAP, VMP Elbow, 82mm, JLT CAI & Catch Can, Eiback Sports, Steeda Cambers & Adj UCA, Adj panhard & Brace, LCAs+Relos, Diff Bushing, Ford Diff Cover, Axle Catch Can, 3.73, Shaftmasters DS, MGW, BG Syncro II, Blowfish Shifter Support Bracket, Trans Mount Insert, MBRP 3" H pipe, Borla 3" Touring Pipes/Axlebacks, High Flow GT Grill Insert, Steeda Spyder Wheels (20X9.5/11), 275 fronts, 315 rears, Lakewood drag shocks, Cervini Hood, big smile
Beviking is offline   Reply With Quote
What do you do when you completely flush out a cooling system and the car still runs hot? Dru General Mustang Discussion 5 04-02-2010 03:59 PM
cooling system flush - Help!!!- 00stang3.8 Pre-2005 V6 Mustang 2 11-11-2007 11:10 PM
Need help with cooling system Dman Pre-2005 V6 Mustang 5 06-16-2007 10:35 PM
Burping the cooling system? I_luv_HP&trq General Car Discussion 2 09-06-2006 09:55 PM
My Cooling System 04MonteSS The Bar 12 07-30-2005 03:50 PM
» Premium Vendor
09:01 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
