Heater hose. - Mustang Evolution
Old 03-04-2019, 05:26 PM   #1
Heater hose.
Hi all. I bought a Haynes manual today (no help)and googled for more than 3 hours trying to find what needs to be done to remove the heater hoses from the firewall. I want to replace all the hoses. I have a 06 V6. Thanks for any help.
fiftyslost is offline   Reply With Quote
Old 03-05-2019, 07:42 AM   #2
What part do you need help with?
Is it the quick-release connectors that are giving you trouble?
Old 03-05-2019, 10:11 AM   #3
Yes the quick connect. I wanted to know if is possible to remove the hoses from the firewall without removing the intake manifold and what method to use. I have not started the replace. Waiting on the rest of the hoses. Trying to find out what I'll run into beforehand. Thanks for responding straybullit.
Old 03-05-2019, 10:56 AM   #4
I'm not totally sure, as I have the previous generation of Mustang, but I would be surprised if changing any of the coolant hoses required disassembling the intake manifold. It should be fairly straightforward, with the usual frustrations of working in a confined area.
You will need to get a set of tools to release the quick-connect hoses, if you don't have them already. Sometimes the quick-connect hoses can be stubborn to remove, just keep at it and they will eventually come loose.
Just work slow and methodically, carefully inspecting each hose to determine the best way to remove them. If something does happen to need to be removed to provide easier access to the hoses, be sure to document how it was connected so that it can be reinstalled properly.
Old 03-05-2019, 12:07 PM   #5
Thanks straybullit. I'll see if I can find a tool for the quick connectors. The tabs are at the end of the elbow.
Old 03-05-2019, 12:11 PM   #6
I took a picture but can't figure out how to post it.
Old 03-05-2019, 12:25 PM   #7
You can purchase an inexpensive set made of plastic, or, most of the "big box" auto parts stores will have a set of "loaners" that you can borrow.
Again, not positive that your car has the same type of heater hose connections as mine, but you will see what type that you have, and what will be required as far as tools go, by inspecting the new hoses.
Good luck!
Old 03-05-2019, 12:30 PM   #8
[IMG][/IMG] Thanks much.
Old 03-05-2019, 12:32 PM   #9
I haven't used it for.some time, but I used to use the Mustang Evolution app to post photographs.
Old 03-05-2019, 12:36 PM   #10
And you might need a certain amount of posts for the photos to post immediately. Otherwise,the photos may need to be approved by management before they will post.
Old 03-05-2019, 12:37 PM   #11
Thanks for all the help.
Old 03-08-2019, 03:54 AM   #12
RBK
RBK's Avatar
I don't know if this applies to your situation but it used to be that the heater hose would connect directly to pretty flimsy tubes coming out of the firewall that are part of the heater core. If this is the case be very gentle when removing those hoses, what I use to do is take a razor blade knife and slit the hose from the firewall towards the engine and then carefully peel it off the tube; do not go pulling on it with any force as nothing good will happen if you do.
RBK is offline   Reply With Quote
heater hose Cdbformula 1996-2004 Mustang GT 8 12-24-2012 11:17 AM
Heater hose came off manifold 96carsrus 1996-2004 Mustang GT 0 11-17-2012 07:19 PM
Quick fix for heater hose spout on intake? 96Roushgt 1996-2004 Mustang GT 1 09-06-2012 11:02 AM
Heater hose 02silvermonster 1996-2004 Mustang GT 8 04-08-2012 11:37 PM
My heater scuks in fumes when I turn on the heater jaynez31 Pre-2005 V6 Mustang 3 02-08-2006 06:44 PM
» Premium Vendor
12:36 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
