Radiator Fan Replacements - Mustang Evolution
Old 04-05-2019, 02:34 PM   #1
ActorMike's Avatar
My radiator fan is squeaking a little when I turn off the car as the fan comes close to a stop. I was thinking about replacing now. Can I use any of the 70-80.00 fans on Rock Auto? Wanted to make sure they were an exact replacement if it was two speed for example.
ActorMike is offline   Reply With Quote
Old 04-13-2019, 01:30 PM   #2
ActorMike's Avatar
I'm glad I noticed the slight squeaking of the radiator fan when the car was turned off because I replaced it and one of the ball bearings from inside was actually wedged in the outside of the fan! The new fan is much quieter than the factory fan as well and spins freely long after the car is shut off, so it definitely has very little resistance. The Motocraft fan was too expensive so I got the TYC 621070.
Old 04-14-2019, 05:24 PM   #3
Interesting, what mileage did the factory fan fail at? Do you run the AC alot?
14v6spdNJ is offline   Reply With Quote
Old 04-14-2019, 05:33 PM   #4
ActorMike's Avatar
Not really sure when it happened. It was a barely noticeable squeak after the car was turned off as the fan came to a stop. I knew that wasn't normal so replaced at 98k miles. No telling how much longer the fan would have worked before total failure.
Fuel pump replacements Count Dragula 1996-2004 Mustang GT 24 04-07-2013 07:00 PM
ball joint replacements. Audicrashdummy 2005-2010 V6 Mustang 3 01-02-2013 08:53 AM
JLT CAI filter replacements back n a stang 2011-2014 Mustang GT 7 05-10-2012 09:38 PM
Pad/Rotor Replacements for Brembo's? GrayGhost 2011-2014 Mustang GT 0 02-12-2012 10:51 AM
Roush 13-inch Rear Rotor Replacements? 3ricchu 1996-2004 Mustang GT 2 11-16-2009 07:14 AM
» Premium Vendor
09:09 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
