RPM drop - Mustang Evolution
Old 05-24-2019, 09:56 AM   #1
RPM drop
Hi Guys,
I need a little help diagnosing an issue with my v6 convertible.
My car is having an issue after driving that when I put it in part the RPM's just drop out from around 700 to 500 really fast. They then jump right back up to 700 and resume normal idle after a quick studder in the engine. A few times recently however after putting the car in park it has literally just cut the power completely. While this doesn't happen often it has happened on at least 5 occasions in the last 3 months. I brought it to my mechanic and asked about the idle air control valve. I don't even know that this car has one like previous mustangs? Maybe you guys can clarify that one, or is it the MAF? Is my throttle body bad? I had my spark plugs replaced recently. I also went from 2.73 gears to 3.55 gears but the problem existed before and after the gear upgrade and that should not be related. I've read that it could be a vacume leak but the car runs completely normal while driving until I put it in park and again it is a problem that is inconsistent.
There is no check engine light on. My mechanic checked this 2 months ago and said there were no codes at all and he thoroughly tested it for me.
One other thing. I am using a pedal commander for throttle sensitivity. I don't think that should cause a problem but you never know I guess. I'm not sure if I had this problem before I started using that but seems more like a hardware issue to me.
Any help is appreciated. Looking forward to your responses.
Thanks.
cdenigris is offline   Reply With Quote
Old 05-24-2019, 10:26 AM   #2
TCU-6612's Avatar
https://www.mustangevolution.com/forum/f356/t392377-2/
Changing the throttle body helps a lot.
---------- Post added at 10:26 AM ---------- Previous post was at 10:26 AM ----------
1966 Mustang straight 6 Red and White
2012 V6 MCA Silver
C/S Spoiler, JLT Catch Can, Airaid Modular Intake Tube w/ Ford emblem, AFE Pro-Dry Air Filter, Polyurethane Swaybar Bushings front and rear, LED Interior lights, LED License Plate bulbs, LED Reverse Lights
TCU-6612 is offline   Reply With Quote
Old 05-26-2019, 04:44 PM   #3
JokerS197's Avatar
Yeah I have been experiencing the same thing lately with my convertible. I had a check engine light come on, said an O2 sensor was bad. Replaced the O2 sensor, seems to idle better now. I doubt the O2 sensor will impact the idle when shifting to park. I have cleaned the MAF and it really didn't make much of a difference. I am assuming it could be a vacuum leak? But haven't found anything yet.
Sent from my SM-G960U using Mustang Evolution mobile app
JokerS197 is offline   Reply With Quote
Old 05-28-2019, 12:49 PM   #4
MustangDawg's Avatar
OP:
Pretty sure you need a tune since you changed the rear end gear ratio. I think the only stock tune that Ford provided for gears higher than the 2.73 was the performance package which had the 3.25 gears. I’m not sure if that has anything to do with your idle issue, but when you go higher than 3.25 gears, you need a tune to compensate for the gear change. I don’t know if you have the stock tune or a custom tune as that wasn’t mentioned in your original post.
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
MPT Tuned, JMS PedalMax, Borla S-Type Axle Backs, Airaid CAI, SR Perf. Strut Tower Brace, JLT Oil Separator, MMD Side Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Steeda Pro-Action Shocks & Struts, Eibach Pro-Kit Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR Rear LCAs w/Brackets, BMR Panhard Support Rod, Whiteline Adj. Panhard Bar, Ford Boss 302 25mm Rear Sway Bar, Ford Racing Finned Diff. Cover Plate, Royal Purple Gear Oil, Philips X-tremeVision LED Fog Lamps
MustangDawg is offline   Reply With Quote
Old 05-29-2019, 05:14 AM   #5
David Young's Avatar
I believe he had his Bama 'tunes for life' changed for his 3.55 gears
Performance Package v6 Mustangs has 3.31 rear gear ratio
David Young is offline   Reply With Quote
Old 05-29-2019, 03:45 PM   #6
Thanks for the clarification on the gears, I knew the performance package gears was less than 3.55, I just couldn’t remember. I also couldn’t tell from his post if he was tuned or not. Anyway, never mind
Old 05-29-2019, 08:52 PM   #7
Yes thats right. I have the bama tunes for life. This problem is pre gear swap. The throttle body may be the issue. I'm going to disconnect my pedal commander this weekend and see if it improves it but otherwise, there is now IAC that I know on my car. I will have the TB completely removed and cleaned inside and out if i have to. I guess the mechanic only sprayed in there even though I told him to clean it last time.
Old 05-30-2019, 11:59 AM   #8
TCU-6612's Avatar
You need to remove it to really clean it good on the back. I replaced mine and the dropping has stopped or at least decrease substantially.
When I replaced mine it was shiny and clean on the front but then I saw the dark side. The back was filthy and there was a rim of gunk where the throttle plate stops.
2012 V6 MCA Silver
Old 06-01-2019, 01:13 PM   #9
Absolutely correct! Take the TB off and clean it. It’s a really simple DIY job. It’s a total rip-off to have a mechanic clean it. I clean my TB and MAF annually as part of my scheduled maintenance.
RPM drop KARgt13 2011-2014 Mustang GT 19 11-21-2013 09:31 PM
Drop or no drop OzzyLiriano 2011-2014 Mustang GT 15 12-10-2012 12:04 PM
Rpm drop alexak187 1996-2004 Mustang GT 13 03-08-2011 12:14 PM
rpm drop classman Pre-2005 V6 Mustang 9 07-22-2010 07:59 AM
RPM drop Murph00 Pre-2005 V6 Mustang 12 07-16-2005 12:32 PM
» Premium Vendor
10:12 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
