1st time flushing coolant - Mustang Evolution
Go Back   Mustang Evolution > 1979-Current Mustang GT || Tech and Talk > 2011-2014 Mustang GT
Old 03-08-2019, 10:39 PM   #1
Been doing some research on the subject before i proceed.
Havent got under the car to check, is the petcock located on the passenger side (yellow knob)? Does our radiator have a bleed valve?
Please let me know if im missing any steps
1. with cold engine, remove reservoir cap and drain radiator petcock
2. tighten petcock and fill system up with distilled water
3. start engine and have heater on max idle for 10-15mins
4. watch temp gauge and add more water if necessary
5. turn off engine let it cool, drain the water
6. refill coolant, turn on engine
7. have heater on max, top of coolant
8. let it idle 15min with reservoir cap off to burp/bleed air out o f system
13' Mustang GT, A6, Whiteline adj. phb & support brace, Roush a/b, Boss 302 brace, Pioneer door speakers, Alpine 10" 500 Watt RMS Amp and Sub, Michelin Pilot Super Sport
winkawak is offline   Reply With Quote
Old 03-10-2019, 06:25 AM   #2
RBK
RBK's Avatar
Did my 2012 V6 about a year ago before I sold it and your procedure sounds correct. The most important thing is to use Motorcraft coolant and distilled water. The Motocraft is not cheap but from what I read other coolants can cause a lot of harm in the engine. I also start my engine after everything is drained, for a few seconds to let the water pump push anything else out. In the old days the engine blocks had drain plugs that would allow you to drain everything in the block, but today they don't have them so there is still some coolant sitting in the block. I don't use the 50/50 mix coolant as I don't think you can get enough into protect in cold weather climates due to the water sitting in the block. Use full strength and pour 1/2 of the system capacity in before adding any distilled water. As I remember I couldn't even get that much in before it was full.
RBK is offline   Reply With Quote
flushing radiator jimmy_beaner Pre-2005 V6 Mustang 12 08-26-2014 05:23 AM
flushing the system Butch General Car Discussion 0 10-22-2012 11:46 AM
Any tips and Such for 1st time Run on Track graystangguy06 Pre-2005 V6 Mustang 11 07-28-2005 08:27 AM
flushing radiator tomorrow morning jimmy_beaner The Bar 1 07-02-2005 08:22 PM
Flushing the brake system and adding new fluids. Brent Pre-2005 V6 Mustang 3 04-25-2005 05:16 PM
» Premium Vendor
09:28 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
