Problems with hood at high speeds - Mustang Evolution
Go Back   Mustang Evolution > 1979-Current Mustang GT || Tech and Talk > 2015+ Mustang GT
Old 01-19-2019, 09:53 PM   #1
Does anyone else have issues with their hood looking like it's going to fly off when driving at higher speed or against the wind?
Sent from my SM-G955U using Tapatalk
dcfogle is offline   Reply With Quote
Old 01-20-2019, 09:07 AM   #2
What year is your ‘Stang? How many miles on the car, and has it ever been in an accident?Is the shaking of the hood mostly at the front or the back? Has it always done this?
Old 01-20-2019, 10:37 AM   #3
It's a 2015. Sorry I forgot to put that in there.
Old 01-20-2019, 12:04 PM   #4
No, I have not noticed this on our 2015 at all......have you checked when the car is in the garage how much the hood might flex if you pull/push on it? You might need either the latches or the hinges adjusted.......I do think that the hoods on the 2015+’s are aluminum, which will flex a bit more than a steel hood, but still, ours does not move noticeably even at triple digit speeds......
Old 01-20-2019, 12:55 PM   #5
When parked everything looks good. I recently put a new hood latch on and it's solid. Everything seems to be aligned properly. I guess its and aluminum thing. Still I thing I'm going to get some hood pins just to be safe. Lol
Old 01-20-2019, 01:37 PM   #6
scurfie's Avatar
130 in mine and the hood didn't move, not that I was paying attention.
scurfie is offline   Reply With Quote
Old 01-20-2019, 02:03 PM   #7
Trust me it's not something you miss. I need to check everything very carefully and make sure nothing is wrong or out of place.
Old 01-20-2019, 04:07 PM   #8
Gil05GT's Avatar
Region: Oregon
Hm, with the hood properly adjusted it shouldn't move; that being said I'ed put on hood pins just to be safe.
2012 Shelby GT500
'05 GT Sold
Gil05GT is offline   Reply With Quote
Old 01-20-2019, 05:08 PM   #9
I am for sure.
Old 01-20-2019, 07:48 PM   #10
My first generation Bullitt does the same thing. On that car, I believe that the problem is the bump stops that support the outer edges of the front of the hood are out of adjustment and are allowing the hood to flutter during higher speeds or even strong headwinds.
Old 01-20-2019, 11:02 PM   #11
That's exactly what's happening. So to fix that should I adjust up to make it tighter or down to make a smaller opening for air to get threw?
Old 01-21-2019, 12:04 AM   #12
Well, in my case, the bump stop on one side needs to be adjusted up, so that the hood will rest on it to keep everything solid across the front of the hood.
I must caution you, that if you adjust those bump stops too high, you will run the risk of the hood latch not securely latching, which can result in the hood flying open at a most inopportune moment.
So that is something that you absolutely want to do correctly.
The hood should just rest on those bump stops, when the hood is fully closed and the latch is completely engaged. They are there to act as a resting point for the outside edges of the hood. They are not intended to be shock absorbers, or anything of that sort.
If you put a couple of soft pieces of clay on top of each bump stop, and then close the hood completely, the thickness of each piece of clay should give you a good indication of whether the bump stops need adjustment, and, if so, by how much.
Old 01-21-2019, 05:30 AM   #13
Strange Mud's Avatar
under car aero shielding? ie oil pan cover/windage tray...check those
Mud
Old 01-21-2019, 07:17 AM   #14
Thanks for the advice.
Old 01-21-2019, 02:48 PM   #15
Cisaacsen's Avatar
My hood on my 2014 GT did the same thing the cause of it was the underbelly shield for the oil and filter was loose causing disruption to the hood at high speeds.
Cisaacsen is offline   Reply With Quote
Old 01-25-2019, 05:23 AM   #16
RBK
RBK's Avatar
I just saw where the 2020 GT500 has hood pins because Ford noticed that the hood starts to rise at high speeds and they needed the pins to keep it down. Could be that all Mustangs will do this at very high speeds and they finally figured that a car that can do 200 MPH should have them.
RBK is offline   Reply With Quote
Old 01-25-2019, 07:57 AM   #17
Thank for all the input. I'm going to check the splash shields and I'm definitely getting hood pins.
Old 01-26-2019, 07:57 PM   #18
Sterling S197's Avatar
I bought my 2017 new, and it has always had a lot of hood movement at high speeds. It seems to be adjusted properly, and all of the underbody aero pieces are in place. Under the right circumstances, wind will cause a lot of movement as well. I've considered putting hood pins in it, but haven't done it... yet.
- Sterling S197 (aka Magnetic S550)
Sterling S197 is offline   Reply With Quote
Hood vibrating at high speeds lzy54610 2011-2014 Mustang GT 9 04-04-2016 08:54 AM
Hood vibrating at high speeds Eric5oh 2011-2014 Mustang GT 22 06-25-2015 07:32 PM
Rear swaying at high speeds... Mustang32Bill 2011-2014 Mustang GT 10 11-22-2014 10:20 PM
Rattling at High Speeds VTHokiez 2011-2014 V6 Mustang 10 10-28-2014 05:54 PM
Freakin Awesome. Comcast Ups Their Upload Speeds Brent The Bar 5 07-05-2008 04:47 PM
» Premium Vendor
» Members Mustangs
GT
aclsallen
Nokia
2014Vert
Add your Mustang
06:27 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
