2011 Mustang V6 - Front End Clunk (Video) - Bad End Links? - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 04-10-2017, 11:12 AM   #1
007Stang's Avatar
Question 2011 Mustang V6 - Front End Clunk (Video) - Bad End Links?
Hey!
This forum has helped me in the past, so thought I'd try again.
Recently I noticed a clunk/bang sound when I turn the wheel (moving and parked) and am wondering what your thoughts are.
I inspected everything as I recently did a break job and nothing appeared damaged, but the end links did have some play to them.
Thoughts?
007Stang is offline   Reply With Quote
Old 04-10-2017, 12:46 PM   #2
DiESeven's Avatar
check your wheel liner. it could be rubbing/hitting against something when you turn the wheel. one thing to possibly rule out.
Old 04-11-2017, 02:59 PM   #3
007Stang's Avatar
Thanks for the suggestion, after inspection I can say it's not the wheels rubbing.
Is this a normal sound? Truth be told, I didn't pay attention to this until I started working on my wife's suspension.
Old 04-12-2017, 11:46 AM   #4
Kristian's Avatar
First make sure all your bolts are completely tightened. If the end links had play in them it is most likely this. End links on these cars go rather quickly, especially if lowered. Try tightening them all the way, when you think youve tightened it enough give it another push because if they arent completely tight you will keep getting clunking noises. From personal experience
Kristian is offline   Reply With Quote
Old 04-12-2017, 01:44 PM   #5
007Stang's Avatar
Thank you for the suggestion.
I'll give them a few cranks after work and see if the noise persists. Car isn't lowered but there are 117K miles on the end links and from time to time I drive it like I stole it....so I guess that the joints could honestly be warn.
I'll report back the results.
Old 04-14-2017, 04:37 AM   #6
RBK
RBK's Avatar
Have a 2012 and was getting the clunk from the rear of my car, had less than 50K miles, and after changing the end links the problem was solved. The one that was bad did not seem to have any play in it but there must have been just enough to cause the problem.
RBK is offline   Reply With Quote
Old 04-19-2017, 07:46 PM   #7
tym_v6's Avatar
Did you check the front brake components to make sure they are properly torqued (caliper pin bolts and caliper bracket bolts)?
2011 mustang
For Trade: My 2014 V6 Front End for your 2011-2012 GT Front End CodyC Mustang Parts for Sale and Wanted 3 03-15-2015 08:42 PM
2014 5.0 front end clunk val916 2011-2014 Mustang GT 12 02-19-2015 08:40 PM
Front end Clunk/Noise 08Mustang 2005-2010 V6 Mustang 5 01-17-2015 12:39 PM
For Sale: Adjustable front sway bar end links Luna1994 Mustang Parts for Sale and Wanted 2 05-14-2013 05:55 AM
Constant clunk in front end suspension Mikeyt03 2011-2014 Mustang GT 28 01-20-2013 02:42 PM
» Premium Vendor
08:04 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
